BTP
- Jan 5, 2018
- Michigan
- 2018 Thundercat, 2019 Thundercat
Now do these come with no springs? Because the numbers all differ in the Canadian catalog and springs are shown witj the shocks.
The shocks above come without springs from Country Cat.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Springs would be a separate part number for each coil....the very rear already has torsions though, so just center and fronts need coils.
You may want to compare your stock spring part numbers to a RR, as there is a slight chance they may be the same coils, but probably not. Coils can have diff part numbers simply due to color too.
Safest bet is to order the coils from an RR in the color you prefer(black I assume).
Dan
Dan
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
Is the first shock for the 129" or 137" skid?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Looks like these part numbers are all for a RR 137".
https://www.countrycat.com/arctic-cat-parts
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
And here are the coil prices for same sled....
looks like front coils are black in color.(#17)
Center shock needs two coils(tender setup) and coupler. (#12,13,14)
Dan
Dan
Wannaviper
- Mar 18, 2014
Thank you Dan!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
If you want to save some cash, you could go with the REAR shock from a Tcat which is still a nice Qs3 but without rebound which many don't ever adjust. No Kashima either.
A VERY good shock for nearly half the cost.
Dan
Dan
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
That's what I'm going with all around from a 19 t-cat. Got the DSC valves from my turbo viper and the valving I ended up with . Can do the three shocks for roughly $1600 CND from cat.If you want to save some cash, you could go with the REAR shock from a Tcat which is still a nice Qs3 but without rebound which many don't ever adjust. No Kashima either.
Dan
I would seriously reconsider using the Tender spring and crossover (communicator)set on the center shock. Many have had the crossover wear into the shock tube. I suspect by this year many will find the wear to be very bad already.And here are the coil prices for same sled....
Dan
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Dan
Does anyone have seat time on both the QS3 and QS3R? I'm wondering if the R's are worth the extra jing for the average trail rider?
I have an SE. To be honest, I'm happy with the front suspension. It's the rear that needs work for me. Too stiff on the small stuff, but not stiff enough on the big stuff.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
You should post the replacement part number for the CENTER COIL , for those who are buying shocks.I would seriously reconsider using the Tender spring and crossover (communicator)set on the center shock. Many have had the crossover wear into the shock tube. I suspect by this year many will find the wear to be very bad already.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
If it were me, I would go with the too dog REAR. Its a 5/8" shaft and can take a serious pounding. Also the rebound can be sped up to HELP with transfer. Certainly more cash over the Tcat rear but worth it IMO. That along with the center shock.Does anyone have seat time on both the QS3 and QS3R? I'm wondering if the R's are worth the extra jing for the average trail rider?
Try that setup and keep stock fronts on SE and see how that does. You can always add the fronts later.
Dan
Both those rear shocks are 5/8 shaft.If it were me, I would go with the too dog REAR. Its a 5/8" shaft and can take a serious pounding. Also the rebound can be sped up to HELP with transfer. Certainly more cash over the Tcat rear but worth it IMO. That along with the center shock.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
So both the Qs3 and Qs3r have 5/8 shafts(rear) but when it comes to the fronts, the Qs3 is 1/2"??
Is that correct?
Dan
