CorrectSo both the Qs3 and Qs3r have 5/8 shafts(rear) but when it comes to the fronts, the Qs3 is 1/2"??
Is that correct?
Dan
Is that correct?
Dan
Have you ever compared the valving between the qs3 and the qs3r on the rear shock? Just wondering if there is much difference besides rebound adjustment.Correct
I usually subscribe to the "Bigger is Better" mindset, but in this case what does a thicker shock shaft actually get us?
5/8" shaft is hollow and allows for the rebound adjuster 1/2 is solid!
Ohlins shocks have had this setup over 25 years ago.Did not realize that. I have a local guy who has been rebuilding and calibrating shocks on my sleds since the days of my 97 SX. He was a machinist by trade and had his shop as a side business, and now in his retirement his garage stays quite busy. He will fix shocks with broken or bent shafts and I have seen his shaft stock. Do not remember any with hollow shafts. Must be something relatively new? I am not impressed if that is so!!
That's why the rebound ajuster is at the end of the shaft. Has a needle valve that moves in the shaft for adjusting flow near the Piston.Did not realize that. I have a local guy who has been rebuilding and calibrating shocks on my sleds since the days of my 97 SX. He was a machinist by trade and had his shop as a side business, and now in his retirement his garage stays quite busy. He will fix shocks with broken or bent shafts and I have seen his shaft stock. Do not remember any with hollow shafts. Must be something relatively new? I am not impressed if that is so!!
No problem! Thats why I bought the equipment and started experimenting on shock valving with my 03 viper 136 I built. Best riding proactive ever . Plush and wouldn't bottom easy, became my wife's sled until she had enough of riding and I sold in 2010
