fourload
58g base weight? I have the TPI rollers , orange primary spring and orange secondary spring wrapped at 60 on the stock helix. Looking for a good starting point as how to load it when I purchase them. Sled is stock and is a LTX with 144 studs. I am about 230 geared up. Will stock muffler tune later in the season or beginning of next year.
fourload
Anyone? Shagman or NOS Pro
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Few pics might help...
Dan
Dan
fourload
Thanks Dan. Is that a 58gram base weight?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Lonn at thunder products will load them for you when you order. Dans weights shown are the setup you will need. Yes 58g base weight.
Sent from my iPad using Tapatalk
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
Lonn set mine up like Dan's except he put a 3/8steel bolt in the center (2.6 grams). I also have the 3/4allen in the heel (3.3 grams) and 3/8 steel and thick washer on the tip (4 grams). So far it seems good and reving out 8800-8900.Lonn at thunder products will load them for you when you order. Dans weights shown are the setup you will need. Yes 58g base weight.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
YepThanks Dan. Is that a 58gram base weight?
shagman
Vendor
- Feb 18, 2014
If you were to change the middle steel to aluminum you would gain rpms in mid range a little quicker and increase top rpm about 100 rpm. You can try it if you want. It’s good either way. That’s the benefit of adjustable weights you can tune to your riding style and what you want to feel without hurting performance.
