What HH base weight for a stock Sidewinder.
fourload
UPSTATE,NY
58g base weight? I have the TPI rollers , orange primary spring and orange secondary spring wrapped at 60 on the stock helix. Looking for a good starting point as how to load it when I purchase them. Sled is stock and is a LTX with 144 studs. I am about 230 geared up. Will stock muffler tune later in the season or beginning of next year.
Lonn at thunder products will load them for you when you order. Dans weights shown are the setup you will need. Yes 58g base weight.
Sent from my iPad using Tapatalk
Lonn set mine up like Dan's except he put a 3/8steel bolt in the center (2.6 grams). I also have the 3/4allen in the heel (3.3 grams) and 3/8 steel and thick washer on the tip (4 grams). So far it seems good and reving out 8800-8900.
If you were to change the middle steel to aluminum you would gain rpms in mid range a little quicker and increase top rpm about 100 rpm. You can try it if you want. It’s good either way. That’s the benefit of adjustable weights you can tune to your riding style and what you want to feel without hurting performance.
