Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
I know there are threads that refer to belts but they typically only have 3 numbers/letters designating which belt your referencing. I am new to Yamaha so want to make sure I’m getting the correct belt. My spec sheet says the belt is 8jp-17641-00. Is this the best belt to buy oem or aftermarket Right now it will be a spare. Thanks for any in put.
Brian
Brian
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Yes use Yamaha factory belt. 8JP.
Some switch to another Yamaha belt 8DN which is cleaner and seem to be much more durable, however you will loose ~10% because it is a slightly longer belt.
Bt04f250
- Mar 6, 2017
- IL
When switching to this 8dn the rest of the numbers would remain the same I take it
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Just tell your dealer the first 3 digits, they should know rest. 8DN or 8JP.
The Gates Carbon cord is a very nice belt that performs well. About same cost as 8JP.
the 8DN is far cheaper then all, so maybe for trail miles its smart, and you can use a dial-adjust to raise the belt above secondary like the doos, for proper deflection (will still be 3mph slow on top only)
Heard the Ultimax last longest by a few guys, costs more too.
Image below is ebay best prices w/free ship and no tax(for most)
Dan
Dan
Bt04f250
- Mar 6, 2017
- IL
Damn Yamaha belts are cheap. My polaris was like 200ish
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,and so are cat belts,my doo belts were like 125-150 not cheap either.Damn Yamaha belts are cheap. My polaris was like 200ish
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks Dan,nice job aligning these up,for us.Just tell your dealer the first 3 digits, they should know rest. 8DN or 8JP.
Dan
theewarrior
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Hmmmm.......pass
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I wish the almighty doo 391 would fit....its quite tough.Anyone ever try other belts like Ski Doo, or arctic cat i've been noticing on some cross reference their belts very similar to ours in length and width
theewarrior
I have the 911 clutch cover where you can adjust driven clutch width so been looking at some thicker belts
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I ran that 911 cover on my apex, loved it...Next season will get one for my winder if I stick with stock clutches.I have the 911 clutch cover where you can adjust driven clutch width so been looking at some thicker belts
Dan
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I just passed 1500 miles today on the original 8JP. It works so well, I see no reason to go away from it, even though I have a couple Ultimax's to try here. I was flogging on it today with the Hurricane 290Race tune pass after pass on the groomed trail, then out in the field in 14" of heavy snow at 8900 RPM. Thing is a beastly animal and very little heat, wear or belt dust. Seems to me the 8JP is a fantastic belt.
I don't see how some are having such problems, or feel the need to go to different belts & rollers and every trick of the week.
WinterWolf
- Mar 25, 2017
- Connecticut
Stock clutching in your sled with that race tune?
KnappAttack
- Feb 19, 2004
- Welch MN
LOL!! No, no where close to stock components.
