fourload
Is everyone going to a conventional multi angle helix when using race or max spool tunes with Dalton weights. Lots more power down low with these quick spooling tunes.
Thats close to where i'm at.I tried the 41/35 , on power max it would pull to 8400rpm then slowly pull to 8700-8800 rpm , the straight 35 will pull to 9000rpm then settle 8900 instantly , at this point I'm stilling liking the straight 35 ,
Similar results found between the 41/35 and straight 35 here except with the 41/35 I'm at 85-86 initially then it pulls up to 88-89. All my best ETs to date are with the 41/35 as well as my best top end. all testing done with a TD GPS. I'll be testing more this week.I tried the 41/35 , on power max it would pull to 8400rpm then slowly pull to 8700-8800 rpm , the straight 35 will pull to 9000rpm then settle 8900 instantly , at this point I'm stilling liking the straight 35 ,
