Snowmobile Mike
- Oct 19, 2018
- East Haven Connecticut
- 2016 Yamaha XT SE
I had a 2014 I think I remember that year was Not a problem !
Now that I'm back with a 2016 this rod problem is come up ,from memory I'm not feeling to good thinking IT IS ON 2016 ! What's some warning signs any thing that could be done in care that could prevent major issues ? It's only got 143 miles on it, I have not driven it let ?
Which years had Bad Rods ? What's the solution ?
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
Early 2016 Vipers had the good engine. The last half of 2016 had the weak rods. If you don’t put a turbo on the sled you should be fine. This thread addresses the issues:
https://ty4stroke.com/threads/is-it-best-to-avoid-the-late-build-2016-sr-vipers-bad-rods.149406/
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
Is there a build date or something on tunnel or does it show up on serial number ?
How do We find out call selling dealer ?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Look in the frequently asked questions section and it will show you how to tell the difference between the early and late build engines. Later builds have the none turbo rods. They are not "Bad Rods" they were redesigned and no longer are strong enough when adding a turbo. If your not gonna boost it ride it like you stole it. There doesn't seem to be a list showing serial numbers or build dates that I have seen.
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
If you pull the side panels and look at the head of the engine, the good engines had rubber half moons on the top of the head, where it meets the cylinders, the non-turbo engines did not have the rubber half moons.
This is also a good thread. It should answer all your questions.
https://ty4stroke.com/threads/2016-5-late-build-viper-changes.137648/
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
I have a 2014, 2015 and a 2016 Viper, and I know that everyone says the 2016 engine is fine as long as you don't boost it, but I swear that my grandson's 2014 XTX with 9,000 miles on it has more "umph" than my 2016 XTX. That being said, I still love my 2016, and I am very happy with its performance.
Jipper
- Mar 3, 2015
- Ramsey,MN
- 2016 Yamaha Viper LTX LE
I have a 16 LTX LE with 2000 miles on it and I ride it like a stole it. Never had a problem except the skis and lack of snow. I have not and will not turbo it. Its a great riding sled once you adjust the shocks to your liking.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Remember its NOT bad rods UNLESS you TURBO. I have never read of a pattern of rod failure on a naturally aspirated VIPER.
This is true. I thought it would happen eventually but it hasnt ever that I know of. Thankfully!Remember its NOT bad rods UNLESS you TURBO. I have never read of a pattern of rod failure on a naturally aspirated VIPER.
The 2016 were the weaker rods. As I've been told, Yamaha sourced someone(I heard Subaru)for their engines after the tsunami damaged some of their factories in Japan. They were not as strong as rods used in earlier vipers as well as Nytros, which I don't think ever had rod issues, even with lots of boost.I had a 2014 I think I remember that year was Not a problem !
Just some engine components.The 2016 were the weaker rods. As I've been told, Yamaha sourced someone(I heard Subaru)for their engines after the tsunami damaged some of their factories in Japan. They were not as strong as rods used in earlier vipers as well as Nytros, which I don't think ever had rod issues, even with lots of boost.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I wouldn't hesitate to buy a 16.5+ if I had no plans to turbo, heck, I'd change out the rods and piston on my 14' If I ever turbo it because I'd become a Boostaholic! Lower compression pistons are a far better solution to running higher boost levels than a head shim down the road.
- 14K
- 121K
