blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Looking to see if anyone knows if there’s an extension plug from hood to sled. That way one could put the hood on the floor and still have the sled plugged in to check for boost leaks or whatever without having to put the hood back on. Thanks
A hood harness extension would be nice. I have been setting the hood down on its nose leaning against the PTO side of the sled for maintenance where the sled needs to power up.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Maybe these companies like hurricane, td, precision, barn of parts or even gap can make them. I’m sure it will be a hit
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
I was actually on cat country and they have a 16 pin plug hood harness extension.It should be the same I have an email into them. I’ll give update when I receive an answer.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Ya I thought I remember there being one available from cat
Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
One on ebay for viper.maybe the same
Yamaha SR Viper Arctic Cat XF7000 Hood wiring harness extension 2014 2015 2016 | eBay
Find many great new & used options and get the best deals for Yamaha SR Viper Arctic Cat XF7000 Hood wiring harness extension 2014 2015 2016 at the best online prices at eBay! Free shipping for many products!
www.ebay.ca
No...don't think that fits the 2017 and up SWs.One on ebay for viper.maybe the same
Find many great new & used options and get the best deals for Yamaha SR Viper Arctic Cat XF7000 Hood wiring harness extension 2014 2015 2016 at the best online prices at eBay! Free shipping for many products!www.ebay.ca
Looks like the Arctic Cat part number is 1686-802 but no one has stock...probably unavailable for ever now.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yamaha part #s for different hood extension harnesses and which years they will fit.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
I bought one last fall from Country Cat for my Cat. I think it was on sale for around $30. Haven't used it yet, but just thought I needed it.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Cat country said no on having them. Thanks to Allen now i have the yamaha part number i'll see if i can find one.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Partspak.com says they have 24 of them, now 23 if it's legit. Order went through, hopefully I won't get an email saying anything different.
I ordered one as well...will have to see if I get it.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I fail to see why one would need this extension.
You're not supposed to do a boost check on the sled gauge, or it will code out and need the clear code flash done to fix it anyway. There was a warning on this many years ago from TD back when they found out the hard way on this.
beanie
- Jun 11, 2005
Country cat sells one but was out of stock last month. Think it was 6 ft. long and under 25.00Looking to see if anyone knows if there’s an extension plug from hood to sled. That way one could put the hood on the floor and still have the sled plugged in to check for boost leaks or whatever without having to put the hood back on. Thanks
I would like the hood extension for a couple reasons at least.
-where I mounted my adjustable FPR, having the hood off makes it way easier to see and adjust
-being able to run the engine with the hood off makes it way easier to check for exhaust leaks
-leaning the hood up against the sled to be able to connect and run the engine can be cumbersome.
