mach9
LJ 452 said:Phazer spindles are totally different and narrower, which would indicate to me that they may be less rugged, possibly a result of the lighter front-end of the Phazer not requiring the strength. I'll try to measure the points if I get a chance, just looking at them both side, by side, I remember thinking I wouldn't want the Phazer spindles on my Nytro. Not from a geometry standpoint, but an apparent strength view.
How much thinner is the question I guess.
Meaning longer ski bolt bushings to mount the ski are required also.
The Nytro spindle is 1.66" or 42mm thick.
mach9
Update...
Just measured the Phazer spindle thickness at the dealer.
39mm thick 3mm thinner than Nytro. (0.118")
Not that much really.
If the gap where the lower ball joint slides in is the same... (which I didn't measure, bah)
I'd say they would go on.
