Will these skiis fit?
09Nytro_XTX
Grand Haven, MI
Hey everyone!
So before i owned my old 2000 SRX my dad owned it. He forgot he had some different skiis on it at one time, and found them in storage. They are USI VX Series skiis.
Now the question i have, will these fit my 2009 Yamaha Nytro XTX? Im guessing no, but it would be really nice if they did! They are damn nice! I would try to see if they fit myself, but i wont have my Nytro until later in the week.
Below is the pat numbers if that matters..
Pat#5040818
Pat#5145201
And here are some pictures..
damn that is awesome news!! I have yet to try the stock skii set up, but if they arent worth a damn itd be nice to have these to use
You'll be switching skis, Yamaha can't make skis. LOL
Should fit no problem, as mentioned just use the stock rubber and maybe a shim or two if you need to tighten it up. I swapped USI's from my Apex to a friends 08' Nytro. Since the spindles mounts are the same on the SRX as the Apex it should work out.
I am running damn near the same ski on my 09 RTX except mine are USI PX 301's, they are much better then the stockers but I now need to reduce ski pressure cause the really grab, should work fine only possible thing could be different bolt size like I ran into but I had a guy turn new ski bushings to match my Nytro , easy fix, you will like them
