jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
No problem! Just realize when you get low on fuel your going to have to go easier on the flipper. Don't want to spit a shim on this motor from a LEAN back fireOk i'll look into it. I usually don't let tank get to low but there might be that day. Thanks for the heads up.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Took fuel pump out of tank, no debris in tank, fuel socks look good, nothing loose or dirty, no cracks or anything of that sort
Fords4life
- Dec 7, 2021
- South Dakota
While out did you hose the filters off with carb cleaner?? Looking clean and clean are two diffrent things.Took fuel pump out of tank, no debris in tank, fuel socks look good, nothing loose or dirty, no cracks or anything of that sort
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I'll try that before I put the pump assembly back itWhile out did you hose the filters off with carb cleaner?? Looking clean and clean are two diffrent things.
- 12K
