Looking in the 04 tech update manual, shows 4 pics, figured out 2 of them, the last 2 not sure. One is below the thermostat area around the carb boot showing a head bolt, and other is above the right foot rest area showing the relays/fuses not sure Thanks
SIMMER
This bolt gets changed to an ACORN style nut to prevent it from rubbing through the flat thin black wiring plastic harness on the inside of the frame above it....you will see damage if it has been rubbing.
The relay is grounding out somewhere while the machince is running..I had my dealer investiagte it last season...I kind of found it by mistake....if you listen you can hear a faint clicking sound somewhere around the footwell area. I am not sure what they intend to do about it but it sounds to me as if it has been addressed.
