ds661
- Nov 25, 2017
- ontario
- 2017 sidewinder rtx le
Today I purchased aftermarket handwarmers to install on a 2008 Nytro. The warmers have blk/red/ white wires and instructions say that 1 is high 1 is low and 1 is ground. They are to be wired into the existing switch wiring which is only 2 wires.... Do i wire high/low together and 2nd wire is the ground? I know everyone recommends the yamaheaters and RSI etc but i needed heat and want to get out there.
Any direction is appreciated.
dennyboy
- Oct 4, 2013
- Minnesota
- 2012 nytro XTX 1998 srx 600
yes both powers to one wire and the ground to the other. that's what I did with mine. What brand did you get?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Ground wire doesn’t go to the switch it goes to chassis ground. The high and low go to the switch
ds661
- Nov 25, 2017
- ontario
They are just an aftermarket from a supplier. I just didn't want to blow a fuse or something by wiring wrong.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Oh I see one wire is already ground. Ecu adjusts voltage to warmers through one wire. I suppose you could tie them together or just use the high
ds661
- Nov 25, 2017
- ontario
So, as an update. the new grips had 3 wires and the stock heaters only had 2. I ran a ground off the new grips and connected the other 2 wires to the stock 2 wires. worked fine today in -14C temps.
