mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
Hade one that hade a small leakage in the exhaust port cyl2 when sitting under pressure over night.
Allmost imposible to find. Need to remove header to see it.
HABS 1
- Oct 22, 2015
- corunna,ontario
curious if that was leaking like that from day 1 for you? or start later on at a certain milage?Hade one that hade a small leakage in the exhaust port cyl2 when sitting under pressure over night.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
It was a Demo machine got 800km om it,
I got to return it an got a New one,
Dealer change the head and it was ok.
HABS 1
- Oct 22, 2015
- corunna,ontario
nice... mine aint burning it , its in the oil confirmed.. but i guess it shows their can be different casting issuesIt was a Demo machine got 800km om it,
HABS 1
- Oct 22, 2015
- corunna,ontario
HABS 1
- Oct 22, 2015
- corunna,ontario
HABS 1
- Oct 22, 2015
- corunna,ontario
installed head studs snd a cometic gasket both bought from td,i checked the head for warpage with a machinest straight edge i have.. it was perfect, i didnt get the head pressure tested, i would have to find a place around who could do it and everything looked good (1200 miles) on the machine, so i didnt bother, checked all valve clearance before disassembly all were in spec,3 were at the (tightest) limit, so on reassembly i shimmed them to mid spec... vacuumed filled the coolent so there shoukd be no wondering if coolent is lost due to air pockets before... sled started n ran great , put 1 heat cycle in it.. ill let cool and do another heat cycle , probably 3-4 of em and hope thd coolent stays where its supposed to be..i love working on sleds but this job was not enjoyable!!! thanks for the help n suggestions from everyone especially turbo flash who gave me some tips n tricks n parts numbers etc... hopefully this ends this post lol
Judging by the pic, it looks like the right cylinder pictured was the one getting coolant in it.installed head studs snd a cometic gasket both bought from td,i checked the head for warpage with a machinest straight edge i have.. it was perfect, i didnt get the head pressure tested, i would have to find a place around who could do it and everything looked good (1200 miles) on the machine, so i didnt bother, checked all valve clearance before disassembly all were in spec,3 were at the (tightest) limit, so on reassembly i shimmed them to mid spec... vacuumed filled the coolent so there shoukd be no wondering if coolent is lost due to air pockets before... sled started n ran great , put 1 heat cycle in it.. ill let cool and do another heat cycle , probably 3-4 of em and hope thd coolent stays where its supposed to be..i love working on sleds but this job was not enjoyable!!! thanks for the help n suggestions from everyone especially turbo flash who gave me some tips n tricks n parts numbers etc... hopefully this ends this post lol
HABS 1
- Oct 22, 2015
- corunna,ontario
right hole plug was whiter thsn the other 2 allsoJudging by the pic, it looks like the right cylinder pictured was the one getting
