ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
.Just grind a couple grams off the back of the weights.
You guys got more money than......
Could you please explain just where is the "back of the weight".
Turboflash
- Mar 18, 2019
- Southern MN
Side opposite the surface the rollers run on.
number1kyster
I would bet you would be at over 9k with MS 16 being it is 10-20 more than Powertrail’s supposed 250. If you went to a lower rate spring than the stiff orange TP I use it would probably work.
Went out for my first ride of the season today. Stock everything with a 500 mile 8JP on. 8,650 RPM at WFO reading 109 MPH.
I will be trying my XS belt once the trail conditions improve.
Turboflash
- Mar 18, 2019
- Southern MN
XS belt will likely make RPM even lower. 8650 is too slow and with XS it will be lower. Gonna have to lighten weights up.
snow_rider
- Apr 2, 2009
- Tawas City MI
- 2018 Sidewinder LTX-LE 50th
I was finally able to get out with my machine, and after 30/40 break in miles on the XS, completely stock 18 LTX, I was able to get to 8750 on full throttle, a tad low, but I think it will settle in a bit and I should see the magic 8800 at some point. I was surprised I wasn’t down the 400/600 RPM’s some have seen? This belt definitely seems ‘bitier’ then 8JP too.
number1kyster
Or, flash it to bring the RPMs up.
snow_rider
- Apr 2, 2009
- Tawas City MI
Thought has occurred to me
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Are you looking at the max RPM recall, or watching the tach as your moving?
snow_rider
- Apr 2, 2009
- Tawas City MI
I was just watching the tach as I drove down a long straight away.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Here’s the deal. If yer slipping with the 8JP or 8DN and switch to the XS belt (that sticks better) your rpm will drop significantly. If yer not slipping with the harder belts then the drop is less. I only had about a 250 rpm difference, if that when I switched.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This year I have only run the xs825 belt.
Most of the time on the 270r tune and one ride on the 290r tune. So far about 700 miles on belt.
I can't confirm that the belt fixed my belt issues as I had my tunnel bowed up and letting snow in the engine compartment from over the top of the heat exchanger. After fixing that it seems my belt issues are gone. May have to go back and revisit the 8dn belt to see how it reacts now.
But for now just going to see how far this xs825 belt will run on the 270r tune.
Tim
Tim
fourload
The XS belt is still doing great. Very consistent clutching with the stock weights and Powertrail. Put another 80 miles on it yesterday . I did find a place to finally run it up to 120 on the speedo before letting off . Pulls nice up top. Boost was 15.7 to 15.9 on the meter. Stock BOV seems to be holding pressure fine.
Also got a chance to ride and race a friends 205 hp Hurricane 900 TDoo. Nice sled with good power but not Sidewinder power . Traction was terrible yesterday so we only did rolling starts. I could check out pretty easily from him after 60mph or so. He went home depressed because he thought he would give me a race. Lol
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Silly Skidoo guy, winners ride Yamaha’s
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Dont forget to remove and inspect your belt after each ride. 850 miles on this xs825 belt.
Alot going on in this photo. Hope it shows up on here like it is in person.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea that’s toast. I bet your clutches are pretty hot.
