yamacharger impellar cover
Yamacharger
Yes Andy it is your old sled and you kept it very clean and in a good state of tune, the best it ran with your setup was 117.8 on radar, my rtx with clutching and a 1 inch hacksaw in the same conditions ran 122 (that is no power adders at all) You know as well as I do that there is more to the 133 than the yamacharger. Doug
Just got a good run about 1/2 mile perfrct condictions stock apex ext to 136 with 1.5 ripsaw 115mph speedo. My Attak with everything listed below 130mph speedo.
speeds
The 130 on the speedo is right around 117, they are out 10 percent plus at the high speeds for example at 151 speedo translates into 132-134. The speedos are close to accurate at trail speeds and the new one is real close.
Re: speeds
not sure about that..what i have found before on testing with radar.- 7 to 8 mh and i aim sure that each sled is different.(speedo) at wot.
Re: Yamacharger
I got 119 on GPS with that sled with all the mods with the stock ripsaw track and 96 studs and stock clutching on a plowed ice road.
