drdoug
- Feb 6, 2007
- Sudbury Ontario
- 2024 Sidewinder SRX LE EPS
Yamacharger
Yes Andy it is your old sled and you kept it very clean and in a good state of tune, the best it ran with your setup was 117.8 on radar, my rtx with clutching and a 1 inch hacksaw in the same conditions ran 122 (that is no power adders at all) You know as well as I do that there is more to the 133 than the yamacharger. Doug
Just got a good run about 1/2 mile perfrct condictions stock apex ext to 136 with 1.5 ripsaw 115mph speedo. My Attak with everything listed below 130mph speedo.
drdoug
- Feb 6, 2007
- Sudbury Ontario
speeds
The 130 on the speedo is right around 117, they are out 10 percent plus at the high speeds for example at 151 speedo translates into 132-134. The speedos are close to accurate at trail speeds and the new one is real close.
Yup the speedo's are off but for a sled setup for off trail I think thats pretty good.
MUSKIE
Re: speeds
not sure about that..what i have found before on testing with radar.- 7 to 8 mh and i aim sure that each sled is different.(speedo) at wot.drdoug said:The 130 on the speedo is right around 117, they are out 10 percent plus at the high speeds for example at 151 speedo translates into 132-134. The speedos are close to accurate at trail speeds and the new one is real close.
ScottyD
my speedo read 120mph when i was going 114mph on the gun
SledFreak
- Feb 7, 2005
- Ontario. Canada
Re: Yamacharger
I got 119 on GPS with that sled with all the mods with the stock ripsaw track and 96 studs and stock clutching on a plowed ice road.
drdoug said:Yes Andy it is your old sled and you kept it very clean and in a good state of tune, the best it ran with your setup was 117.8 on radar, my rtx with clutching and a 1 inch hacksaw in the same conditions ran 122 (that is no power adders at all) You know as well as I do that there is more to the 133 than the yamacharger. Doug
