17 Viper XTX
- Jan 31, 2019
- Rockland, Ontario
- 2017 Yamaha Viper XTX
2017 Viper XTX - no studs - 141 - aggressive rider.
Stock Ski’s with Everlaster runners, they are made by Snowtracker. Not the Snowtracker system just they’re 8” carbide runners.
Made a huge difference over stock runners. Stock was 4/10 new runners 8/10.
Dr. FeeLGooD
2019 xtx le 141. Stock. Fixing it is not in the budget right now.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
19 srx. C&a xpt with slim jim dooly
bankershrs
- Sep 19, 2008
- Roscoe, IL
- 2017 Yamaha Sidewinder RTX LE
'17 RTX LE
Studded
Aggressive trail rider
Pilot 5.7 and aggresive model Snow Trackers. Does everything I want and nothing I don't want! I love this set up but admit it is the only setup I have rode on my SW.
Studded
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
For those running curves, what's the trick? I can't get them to work for me at all. But they seem to be the current winner in aftermarket skis.
For me they steer way too hard. And if I lighten up the ski pressure, they become unpredictable.
Pstn head
Try a set of 6" slim jims carbidesFor those running curves, what's the trick? I can't get them to work for me at all. But they seem to be the current winner in aftermarket skis.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
2017 XTX 141 no studs, aggressive trail Pilot 6.9 with 6 inch carbide in the middle and same on the outside. handling is excellent, turns well and tracks strait as an arrow. tried big carbide on tuners steering was harder but sled would still push bad. very risky driving into corners with speed. I have Hygear Pro Linkage and Custom Axis shocks all the way around and THE suspension is set perfect, no suspension adj. will make the tuners work. i wasted money and time with the tuners. THERE IS NO WAY SOMEONE FROM YAMAHA CAN TEST A SIDEWINDER WITH TUNERS, PUT SOME HARD TRAIL MILES ON AND CONCLUDE THE SKIS ARE WORKING GREAT!!!!'17 RTX LE
Studded
POWERHAULIC
Still running Pilot 6.9 here, 4" center and outside. 137" and studded 4 per bar.
Works great
Works great
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Works great
Same except a bit more center carbide and a few less studs. Big thanks to @ROCKERDAN for the write up on the 6.9's!
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Take out the curve rubbers out and put stock ones back on and run 6 inch carbides with round host bar any make. Makes all the difference in the world! Sled will rail!For those running curves, what's the trick? I can't get them to work for me at all. But they seem to be the current winner in aftermarket skis.
17winder
- Jan 7, 2019
- Michigan
- 17 Sidewinder Ltx Se
Has anyone swapped their tuners for a set of yamaha mountain skis? Is so how do they perform? On trail?
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
SLP Mohawks on order!
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
I've asked this several times on here with basically no response. The Yamaha reps at the Toronto Show said that's what they run instead of Tuners.
If you have had no response then I would guess not many have tried that. Go be the first. I have heard they work but why not just go with whats been proven to work.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Hey I have run '16 Viper MTX skis from day one. I ran shapers, then semi-agressive snowtrackers, then agressive snowtrackers. The steering effort is power steering light but not enough ski bite. So far MTX with semi-agressive is preferred by me. When I added aggressive snow trackers it seemed all I got was more steering effort and darting. My opinion is the MTX skis are not bad, but I am looking for less understeer (more ski bite and turning precision) without heavy steering. I think the fat keel of the MTX ski causes both too little ski bite AND very easy steering. The flotation is definitely enough.I've asked this several times on here with basically no response. The Yamaha reps at the Toronto Show said that's what they run instead of Tuners.
I will be trying CA PRO MTX skis with 6" shapers next time up to ride (early March).
