Roost 'Er
Some great input, everyone viewing please fill out the poll interesting results so far !
PigeonLake
Are the semi aggressive enough? I am thinking the C&A Pro Crossovers with snow trackers. I like the lower profile of the semi aggressive but wonder if enough. The Aggressive on my 08 Apex were amazing.I voted Arctic Cat skis. I am running 2016 Viper MTX skis with semi-agressive snow trackers. I did not need to ride the Tuners. A buddy has Tuner IIs on his '13 Apex SE and I know they push hard. Mainly I want floatation and snow trackers and the Tuner III keel design makes no sense to me. I have heard the new '17 MTX ski works well and that would be cheap but I doubt you can find them unless a takeoff. If I wasn't trying to be cheap I probably would have ordered white Curves.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I really can't say yet. Not enough riding but steering is precise not heavy at all. Main concern so far would be understeer or pushing in soft snow.Are the semi aggressive enough? I am thinking the C&A Pro Crossovers with snow trackers. I like the lower profile of the semi aggressive but wonder if enough. The Aggressive on my 08 Apex were amazing.
up.mi.man
- Feb 23, 2009
- Marquette MI
- 2017 sidewinder ltx se
- Marquette Mi right on trail 417
slp mohawks with 9'' shaper bars i also have 192 studs
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
It says your on a LTX-SE. If possible could you PM me or post where you have your shocks set at.. Like all four of them. What setting on the spring blocks in back? I have SLT skis/w 7.5 shapers and 192 studs and could barely turn the handle barsslp mohawks with 9'' shaper bars i also have 192 studs
up.mi.man
- Feb 23, 2009
- Marquette MI
I took my blocks out I turned my front shocks loosened them all the way and then gave them two clicks. I'm going to also tighten my center shock about 3/4 of a inch and see if that takes some ski pressure off the front. I also set my torsion blocks on medium. It whole different sled major difference with the Mohawks way better.It says your on a LTX-SE. If possible could you PM me or post where you have your shocks set at.. Like all four of them. What setting on the spring blocks in back? I have SLT skis/w 7.5 shapers and 192 studs and could barely turn the handle bars
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks! Major ski pressure on these things.. Not sure how your turning 9" shapers! You must work out!!! LOLI took my blocks out I turned my front shocks loosened them all the way and then gave them two clicks. I'm going to also tighten my center shock about 3/4 of a inch and see if that takes some ski pressure off the front. I also set my torsion blocks on medium. It whole different sled major difference with the Mohawks way better.
You loosened your front ALL THE way and then two clicks.. Not sure I follow.. You on a LTX - SE?
up.mi.man
- Feb 23, 2009
- Marquette MI
Yes I loosened them all the way then two clicks. I was doing the voice thing on my phone and sent it before I read it.Thanks! Major ski pressure on these things.. Not sure how your turning 9" shapers! You must work out!!! LOL
Roost 'Er
Going to try 6 inch square carbides on the tuners next before curve. TTT
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
How do you mount the Pilot ski's to the SW?
super_rash
- Feb 24, 2014
interesting how the curve skis are doing really good...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Working on the LE here tomorrow, will post up a thread maybe by evening.How do you mount the Pilot ski's to the SW?
Dan
Good times
- Nov 1, 2016
- Muskoka
- Sidewinder RTX-SE
How are the pilot 6.9's getting mounted?
Which ski rubber Yamaha or ski doo?
Do you need to shorten ski bushing?
krm
- Apr 22, 2016
- ny
stk. bolts ,stk. rubbers ,grind a little off the front and back of the stk. rubber ,with a grinder ,a little. on the bottom of the stk rubber grind them so they''re flat as you''ll see on the outside of them there's alittle extra rubber .After you have the bottom of the rubber flat grand a little notch in the center on the out sides so it fits over the little plastic thing sticking up in the ski .use 6" shapers in the middle and 4" round bars outside .Enjoy ,it will make the front feel like a 2 stk.now.you also need to remove the bushing in the ski and put them back in from the outside .How are the pilot 6.9's getting mounted?
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Curve s.5kis, 6" curve carbide, stock rubbers. 192 1.5 inch INS hornet studs. Stock settings so far on front. Rear Torsions on 1, Rear shock 1, Transfer blocks out, Mid shock spring tightened up, ( Cant remember measurement) Compression ON 2, Sled is railing in corners now. Light ski pressure, ride is awesome!
- 48K
- 6K
