johnnysnowking
Maybe I should call the C&A garbage and crap skis because it's just my opinion and I'm not your Daddy and if you want to run that junk then go ahead and run them.
How dare you call skis I like garbage lmao. Send me your address. I will mail you some coloring books and a location to the closest safe space. Sensitive like a millennial. I remember when Bruce was Bruce not Caitlin.
Pstn head
What he saidStop with the 6.9 garbage. Yikes. I have a shed full of those crap skis. Go with anything but tuners or ski doo relics
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
I have said it before C & A RZ turn like a car w/no power steering and dart like %##$^%. They turn yes BUT the curves turn just as well. Don't have as heavy steering, Don't dart hardly at all and Grab in soft snow faster then the C&A. C&A's have a split second of push then grab. Curves do not. Speaking from testing on 2 cat turbo's with 9" shapers. The one with curve had 204 1.45 studs. The one with the c&a 153 1.45 studs. I have a set of 5.7 pilots sitting in the shed that I used on my apex. On the apex they had very easy steering, but also were not that great in soft non mealy snow. I had to crank them to bite well and when doing so they would always spray snow right at my face. Also pilots can get sticks/rocks stuck in the u channel on the bottom. Don't ask me how I know... Just my opinion but from the looks of that poll up there^^ it looks like allot have bought the curves. How many doo's do you see in the trees because they didn't make a turn lol? But remember doo's handle amazing
rj998
S
So what carbide for the curves for aggressive trail riding then? 6?-8? Or shaper? Thx jI have said it before C & A RZ turn like a car w/no power steering and dart like %##$^%. They turn yes BUT the curves turn just as well. Don't have as heavy steering, Don't dart hardly at all and Grab in soft snow faster then the C&A. C&A's have a split second of push then grab. Curves do not. Speaking from testing on 2 cat turbo's with 9" shapers. The one with curve had 204 1.45 studs. The one with the c&a 153 1.45 studs. I have a set of 5.7 pilots sitting in the shed that I used on my apex. On the apex they had very easy steering, but also were not that great in soft non mealy snow. I had to crank them to bite well and when doing so they would always spray snow right at my face. Also pilots can get sticks/rocks stuck in the u channel on the bottom. Don't ask me how I know... Just my opinion but from the looks of that poll up there^^ it looks like allot have bought the curves. How many doo's do you see in the trees because they didn't make a turn lol? But remember doo's handle amazing![]()
AXR
- May 5, 2007
- Central NY
I have 8" bergstroms on my curves 144 1.325 studs and had a good test with them last Saturday on very hard set trails with about 1" of icy loose snow on top many glare iced washed out corners and had no problems getting around in Old Forge (I heard there were 2 bad accidents in that area the same day and was not surprised with the hard icy conditions). I put 6" on my dad's but I didn't take the time to switch off and try his winder to see if I could tell any difference. So 6" might be enough but I can't say for sure. With the 8" though I had no issues with it being too much to cross a road or anything if that helps. My friend with the 9" shapers has ran those for years on the cat w/out issue. I really never saw any difference in turning effort with the shapers vs the bergstroms. Now I have heard from many here that the slim jims take away the very minor bit of darting that you may sometimes have with the curves and lighten the steering effort. I think most of those guys are running 6" if I remember correct? I almost went that route but I wanted to try the bergstroms with the ski savers as that is what I always used in the past. Time will tell how well they work once worn a bit. This is the first sled I have ever studded so until now I always had to go a little slower in the turns because the turns here in NY tend to always be washed out and an ice slick.
- 48K
- 6K
