Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I know.... I laughed at them for saying to replace bolts every time. Now who's laughing....
Not the easiest bolt to extract with a very tiny bit exposed. Advice??
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Screw extractor; I had to do that last year.
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
Carefully......weld a nut to it....
Turboflash
- Mar 18, 2019
- Southern MN
Advice?
#1. Don't break them off LOL
#2. Drill it for EZ-Out. Before EZ-Out, heat case around it. Aluminum will expand more than steel screw. Should be loose after heat is applied. Insert EZ-Out and it should unscrew.
#3. Only tighten screws to about 12 ft lbs. The factory torque spec is too high. The case is sealed with a good o-ring. No need for excessive torque. No pressure inside case; there is a vent.
I've used my screws many times without problems.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Yup - all of the above.
Use an Easy out - be patient drilling it. You may want to take a dremmel and flatten the face so its easier to drill in to.
I would hit it with the heat gun to loosen the loctite when extracting.
Good luck.
MS
Good luck.
MS
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Also - when i have the chaincase apart I run the bolts over a die to clean the threads - removing any loctite and then wash them with gas or brake clean. Do the same with a tap on the bolt holes in chaincase. Be real gentle though. Use brake clean to flush them out. It helps clean the threads up - ready to accept the bolt with new loctite. No need to replace bolts - just keep them clean. Been using the same ones for 6 years now.
When i install the chaincase bolts i usually only use a 1/4 drive ratchet. The tightening sequence is real gentle - no need to get viscous or next thing you will be stripping threads.
MS
MS
Doc Harley
- Oct 17, 2016
- Here & there
I'm ready to do that but I've been told not to weld onto or near the magnesium case. IDK?!?!Carefully......weld a nut to it....
Bolts were cranked at hand tightness. I fired the sled up, ran it through the paces and walked away. Found the case leaking, so I grabbed a torque wrench and set it for 135in lbs. (Which is lower than spec of 12 ft lb or 144 in pounds) snap. I swear...Advice?
Doc Harley
- Oct 17, 2016
- Here & there
Bud, I was gentle. Hand tight. Fired the sled up, put it through the paces, and walked away. Came back and chaincase was leaking. Grab the torque wrench and set it for 135in lbs.Also - when i have the chaincase apart I run the bolts over a die to clean the threads - removing any loctite and then wash them with gas or brake clean. Do the same with a tap on the bolt holes in chaincase. Be real gentle though. Use brake clean to flush them out. It helps clean the threads up - ready to accept the bolt with new loctite. No need to replace bolts - just keep them clean. Been using the same ones for 6 years now.
MS
The sad thing in all this, I could feel the bolt twisting but not applying enough pressure, then snap. Yep.... dumb dumb!!! Lol
Turboflash
- Mar 18, 2019
- Southern MN
Try a reverse rotation drill.I'm ready to do that but I've been told not to weld onto or near the magnesium case. IDK?!?!
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Ive always torqued to 96 inch lbs using a quality torque wrench and I do not use any loctite. As long as o-ring is good there wont be any leakage. Reverse drill bit will likely be your best bet but like previously mentioned your gonna want to warm it up to make sure loctite is soft.
Doc Harley
- Oct 17, 2016
- Here & there
Got it. 10min job....
Doc Harley
- Oct 17, 2016
- Here & there
I snapped another bolt in the same location. Hard to believe but I think my chain case guard has been shifted and compromised, pushing it into the back of my case. So as I'm trying to torque the grade #2 bolt, it's actually bottoming out against the cover.
I'll just switch all the bolts over to stainless steel at about .75in length and be done.
Are the bolts bottoming out in the threaded hole? On my SW I found the oil tank bolts tightening depth and rotation torque were restricted by bottoming out in the threaded hole not by tensioning of the tank halves.
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
This may not be your situation but one thing I want to add is if any of the bolt holes/bolts have oil in/on them from draining the oil (bottom two holes mainly) I have found that there is a hydro lock effect and the bolts stretch/elongate. Bottom two bolts are replaced with new ones when I change the oil and holes cleaned with brake clean.
Doc Harley
- Oct 17, 2016
- Here & there
I thought the bolts were bottoming out. But now I believe 100% that they are being stretched & snapping, right around 120in pounds.This may not be your situation but one thing I want to add is if any of the bolt holes/bolts have oil in/on them from draining the oil (bottom two holes mainly) I have found that there is a hydro lock effect and the bolts stretch/elongate. Bottom two bolts are replaced with new ones when I change the oil and holes cleaned with brake clean.
I'm pretty sure they are using #2 grade fasteners to protect the magnesium case. If that makes any sense.
- 13K
