snowdemonsrx
- Apr 18, 2012
01 Rapter won't shift into 2nd gear just grinds, Opened the case and all the gears are prefect no damage all I can see is the left shift fork has witress marks on it from it scraping on the side of 2nd gear, no damage to the gear at all, The Shift Barrel where the shirt fork rides in the groves has a little bur in it, that is the only damage I can find, I was just thinking of replacing that one shift fork and the Shift Barrel/drum! What do you guys think ?
snowdemonsrx said:01 Rapter won't shift into 2nd gear just grinds, Opened the case and all the gears are prefect no damage all I can see is the left shift fork has witress marks on it from it scraping on the side of 2nd gear, no damage to the gear at all, The Shift Barrel where the shirt fork rides in the groves has a little bur in it, that is the only damage I can find, I was just thinking of replacing that one shift fork and the Shift Barrel/drum! What do you guys think ?
Yes as well as debur any thing on those gears... a small bur will cause it not to shift in as well.
