Now you are back to the valves. This thing could just have rust on valves. Check clearances.
No word yet. Haven’t had the time all year and this is on the back burner. Hoping to look further into it soon. Are you experiencing similar issues?Any word on this saga?
I found I have the same issue. I pulled the valve cover and find that when the motor is turning over, the decompressor is not disengaging. Rpms on turnover are 270. I was getting 35 and 40psi on a good gauge. About to somehow lock the weights out so I can get a true compression. Might need to new springs or lighten the weights.No word yet. Unfortunately I’ve been working on my house all year and the sled is buried in the garage.. Hoping to look further into it soon. Are you experiencing similar issues?
There was a kit for the 07'sI found I have the same issue. I pulled the valve cover and find that when the motor is turning over, the decompressor is not disengaging. Rpms on turnover are 270. I was getting 35 and 40psi on a good gauge. About to somehow lock the weights out so I can get a true compression. Might need to new springs or lighten the weights.
