sabrecat
Vendor
- Nov 7, 2013
Cant find a chart to check out stud length over top of lug? I am thinking around 7/16th or .437 ? please no guessing replies. I can do that all by myself.
Thx
Guys!
Thx
Guys!
**sj**
heres stud boy chart
http://www.studboytraction.com/studpatterns/lugheight_studheightchart.pdf
and woody's which I assume you are running...fyi with that size stay out of the center 3.5" unless you add additional aftermarket tunnel protection!
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
I'm with you, and the ones I find, the part numbers are different from actual length or penetration. Doesnt make much sense to me. I installed the woodys GDP6-1325. I can confirm that they are 1.74 overall length with 1.58 installed height, giving .33 over the lug height. And 1.325 corresponds to nothing about the stud.
sabrecat
Vendor
- Nov 7, 2013
So is recommends a 1.325 for the 1 1/4 track . Dose not say what a 1.575 will be in a 1 1/4 track? So do I add to the length to the 1.325 from the difference from the 1.575? I am guessing about 5/8 of penetration then.
This chart is from Snowstuds.
NYTurbo
1 1/4 track is almost 1 1/2 total . A 1.575 stud which is 1.980 will give you close to 1/2 in.
A 1.325 stud in my mind is not long enough.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
1.375" on my 1.25 = .313, just measured.
So, 1.575 should be .513
**sj**
fyi each stud maker nets you different amounts because their shoulder height is different...first you need to decide which stud maker you want....anything over 1.50 into the middle 3.5" without tunnel protector add ons is trouble potentially...here again is my 1.630s staying out of that area...
Soupy
- Jan 10, 2017
- West Michigan
fyi each stud maker nets you different amounts because their shoulder height is different...first you need to decide which stud maker you want....anything over 1.50 into the middle 3.5" without tunnel protector add ons is trouble potentially...here again is my 1.630s staying out of that area...View attachment 133302
"Anything over 1.50" what? OAL? Length from track to tip of Stud? Part number? 1.630 what?
NYTurbo
I ran 2 in OAL studs last year with no issues. Need to keep your track snug as they balloon quite a bit.
Soupy
- Jan 10, 2017
- West Michigan
Which model? Tunnel or heat exchanger protectors?
NYTurbo
Thundercat with factory tunnel protectors. May go to STM protectors if i can fget the factory ones off.
ShootToThrill
1.500 stud boy power points nets me .540 penetration on a 1.25 lug, 2 ply, ripsaw 2.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
1.575 megabytes are just over .5 inch of penetration. Work great on a 1.25 track. The overall length of the stud is 1.98 I believe. This is on a regular ripsaw, I assume all 2 ply tracks are pretty much the same thickness.
Im running extreme max 1.62 on my sidewinder this year, they are 1.92 overall length
It would be nice if these stud manufactures used some sort of standard measurement.
NYTurbo
That' why I only look at the OAL of the stud anymore, measure the track height including belt thickness and you have how much penetration your going to have give or take a 1/16 of an inch.
- 46K
