SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
So my friend and I have heavier springs for the center shock, so fooling around with it the other day, it looks like just drop the limiter straps, unbolt the top shock eye bolt, loosen the spring adjuster nuts, the spring comes loose (no need for a spring compressor), drop the shock down, front or rearward, and slide the spring off! Super easy! Now, mine is an SE with the retainer at the top, and nuts on the bottom. There is 9 inches from retainer to backed off spring seat nuts/collars, and the springs are only 8 inches long. If they planned it this way, kudos to Cat.
Yup thats all it takes. If limiters are in last hole you can get away with leaving them on too. Dont forget to Loctite the bolt.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
What spring did you put in there. I have a ltx le and weigh 300lbs. Any suggestions?So my friend and I have heavier springs for the center shock, so fooling around with it the other day, it looks like just drop the limiter straps, unbolt the top shock eye bolt, loosen the spring adjuster nuts, the spring comes loose (no need for a spring compressor), drop the shock down, front or rearward, and slide the spring off! Super easy! Now, mine is an SE with the retainer at the top, and nuts on the bottom. There is 9 inches from retainer to backed off spring seat nuts/collars, and the springs are only 8 inches long. If they planned it this way, kudos to Cat.
This. I have more coming. Just sold my last one. $70 160lb Bill Mohr center shock spring. I do have my used one I could sell for $50 if in a hurry.
MDGFLHR
What does this spring help with? I weigh 250 dressed and I haven't had any issues with the suspension on my LTX SE but I'm always looking for ways to improve my sled in the handling and ride department.
Lighter front end with less preload. 3-6 turns from snug for most. The less preload used on a spring the less the shock has to work. Preload is stored energy. Stock center springs are lighter spec.What does this spring help with? I weigh 250 dressed and I haven't had any issues with the suspension on my LTX SE but I'm always looking for ways to improve my sled in the handling and ride department.
raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
Does this spring work on qs3 shocks as well?
Yes and if it’s a Qs3r it won’t wear out shock body like stock.Does this spring work on qs3 shocks as well?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Yes, what he said! The 160 pounder.What spring did you put in there. I have a ltx le and weigh 300lbs. Any suggestions?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
When my Apex steering was so much lighter than the sw, I knew I had to do something...lol...it's the rider forward, with so much weight up front. Tightening the stock spring a lot helped..a lot. Since I'm about out of adjustment, it made sense to go to a higher rate. Plus, when the suspension couples, it will pull on that spring too stiffening the whole suspension up. I want a little lighter steering, in the throttle, and less pitch forward, off the throttle. Just looking for more balance.What does this spring help with? I weigh 250 dressed and I haven't had any issues with the suspension on my LTX SE but I'm always looking for ways to improve my sled in the handling and ride department.
The center skid shocks and limiters really play a huge part in handling and steering.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This is off my XTX 137 LE with the standard hpg shock on the center.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
That's it exactly...I think he got them from Cannondale.View attachment 143066 Stock spring on right. 110lb spring. Cannondale spring on left. 160 lb spring.
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
i just ordered one for my 19 btx. the sled has 0 miles on it and first thing I noticed was that the center spring was wound all the way and still had all the weight on the skis compared to me old viper rtx le 1.7
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I have a hyperco 165lb and one of those raptor Tr center springs. Cannondale do you know the final rate of that raptor? I need to build a spring rater.
I don’t recall but is a dyno chart around somewhere. This spring is not a Raptor spring. No adapters needed. Stingray spring.I have a hyperco 165lb and one of those raptor Tr center springs. Cannondale do you know the final rate of that raptor? I need to build a spring rater.
