No I want you to post your specs or pay the vendor fee. Only thing I am disagreeing with you is your a Vendor and not paying.Didn't mean to ruffle any feathers cannon. Just posting my findings. I'm not here to steal your business either. Hope we can agree to disagree now and again without any reprocussions. If you want to pm me feel free my door is always open.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
If i was indeed a vendor i would have paid cannon. I'm not sure where you are getting this info from. I inquired yes. Thats as far as i got. But obviously you have a bee in your bonnet about me so i will refrain from commenting on any of your gospel.
Thank you!If i was indeed a vendor i would have paid cannon. I'm not sure where you are getting this info from. I inquired yes. Thats as far as i got. But obviously you have a bee in your bonnet about me so i will refrain from commenting on any of your gospel.
lilrez
- Feb 7, 2016
- Near Ottawa
Im running two spring setup a 140/300. Parts found on the RR. Seems to work alot nicer than single stock 90/250.
Pstn head
HmmmIm running two spring setup a 140/300. Parts found on the RR. Seems to work alot nicer than single stock 90/250.
Never thought of that thanks.
lilrez
- Feb 7, 2016
- Near Ottawa
3704-033. 70lb#
3704-034. 110lb#
3704-035. 140lb#
3704-036. 170lb#
4604-238 center ring
3704-039 250lb# x 6"
3704-040 -300#lb
3704-034. 110lb#
3704-035. 140lb#
3704-036. 170lb#
3704-040 -300#lb
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Thanks. Exactly what I was looking for. May I ask how much you way fully suited up?3704-033. 70lb#
3704-034. 110lb#
3704-035. 140lb#
3704-036. 170lb#
3704-040 -300#lb
Don’t forget that crossover will ruin the shock.
lilrez
- Feb 7, 2016
- Near Ottawa
Please explain Steve....Do you mean wear from the spring spacer ? Ill take a look tonight.Don’t forget that crossover will ruin the shock.
Is it any different than Hygears twisted dual rate set?
Yes that’s what I mean. Bad idea. Search for my posts and others. It’s ugly.Please explain Steve....Do you mean wear from the spring spacer ? Ill take a look tonight.
Never tested one of their setups on that shock.Please explain Steve....Do you mean wear from the spring spacer ? Ill take a look tonight.
lilrez
- Feb 7, 2016
- Near Ottawa
Me- I am 300 dressed, and the oem 90/250 is undersized . If i simply buy your new heaver springs will it damage/overpower my OEM shock?
Hygear- Our Center dual rate spring kits will not over power the center shock calibration.
lilrez
- Feb 7, 2016
- Near Ottawa
Id like to try the BM center shock spring.......
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I have Bill Mohr's spring, which I purchased from Cannondale for my RTX SE. Overall, my experience has been positive. The stock center shock spring would bottom so easily. It is much better now. The sled was wheelie monster when I first put the spring in(Limiter straps were all the way loose, transfer blocks on 1, springs on 1). I've dialed it back some for trail riding. Overall, I'm happy with my purchase.
My Dad has the Raptor triple rate in in LTX SE. It seems to be more plush than mine, but that could be the difference been the 137 and 129 skids.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
137 SE and that raptor spring is excellent set up for someone 200+ lbs. That spring really changed my ride quality over the stocker. I just snug it up, so not a lot of preload. It’s a great spring ON THE SE 137.
