Joseph Zaloker
- Jan 22, 2020
- Minnsota
- 2016 Yamaha SR Viper LTX
Thank youAt first I removed the airbox but this take too much time.
The right way to do it is to remove the right hand rubber boot at the tie rod and A-arm, so you have an easy access by the right side of the machine.
DS22-HuberWoodsME
- Dec 5, 2020
- Easton Maine
- 2015 SR VIPER MT-X W/MPI TURBO. 153”
I have the same issue but when I go to tighten that 17mm but, the bolt also turns… and therefore can not tighten. Any recommendations there guys? Something broke ?
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
The mount could be cracked but there is a real narrow flat on the stud you put a thin open end wrench on to keep it from spinning as you tighten the nut. Personally if you aren’t sure and the mount hasn’t had the reinforcement kit installed I would take both the airbox and boot off so you can inspect it well and have better access.I have the same issue but when I go to tighten that 17mm but, the bolt also turns… and therefore can not tighten. Any recommendations there guys? Something broke ?
Ok OFT is out of business and I need another decent Stem Clamp/Block for the 7000. Who makes a decent one? Aluminum with a bushing.
saw a set up on ulmer racing site.
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Royal distributing
www.royaldistributing.com
![www.royaldistributing.com](/proxy.php?image=https%3A%2F%2Fwww.royaldistributing.com%2Fmedia%2Fcatalog%2Fproduct%2Fcache%2Ff9bdf7bcf96a325611f356d89b17c75c%2Ff%2F3%2Ff373bce2-ff81-4f2a-b5fd-86cee86845e2_08-08763-master.jpg&hash=44c2a1dc25fafeba6fe19e0501b61b96&return_error=1)
Sports Parts Inc. Aluminum Upper Steering Block
FEATURES These billet steering blocks replace the wear-prone plastic OEM blocks. Machined from 6061 T6 aluminum and bronze alloy bushings, you'll never have to lube the steering shaft bushings again. Precision machined for a perfect fit, bent/warped stee
- 15K
