Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
This is normal. It will happen after the reflash once turn key off wait a few seconds then back on no codes. You ll hear solenoid click also on first key on.Installed my ECU with the powertrail flash today. First time I turned the key I had an SD 84 code come in which is TORS. Started the sled and let it warm up, re started it a few more times. Alarm is gone just curious why it came in on the initial start?
http://www.turbodynamics.ca
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Ok thanksThis is normal. It will happen after the reflash once turn key off wait a few seconds then back on no codes. You ll hear solenoid click also on first key on.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I
I just had a freak out starting my sled for the first time after reflash lol. ThanksThis is normal. It will happen after the reflash once turn key off wait a few seconds then back on no codes. You ll hear solenoid click also on first key on.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I have a 2017 Sidewinder SE 137, with 10,700 miles to date with the last 5,000 miles with the TD 250 hp tune with the quite muffler also from TD. Runs flawless, only thing that comes close is another turbo Yamaha with a bigger tune. Most fun sled to date. Had some issues with durability of Cat chassis, but that's been covered in quite a few other forums.
- 28K
