1550 miles with TD enhancement
Installed my ECU with the powertrail flash today. First time I turned the key I had an SD 84 code come in which is TORS. Started the sled and let it warm up, re started it a few more times. Alarm is gone just curious why it came in on the initial start?
This is normal. It will happen after the reflash once turn key off wait a few seconds then back on no codes. You ll hear solenoid click also on first key on.
http://www.turbodynamics.ca
I have a 2017 Sidewinder SE 137, with 10,700 miles to date with the last 5,000 miles with the TD 250 hp tune with the quite muffler also from TD. Runs flawless, only thing that comes close is another turbo Yamaha with a bigger tune. Most fun sled to date. Had some issues with durability of Cat chassis, but that's been covered in quite a few other forums.
