Rayhall40
- Nov 1, 2022
- Cambridge ny
- 2018 Yamaha sidewinder
I’ve got an 18 Yamaha sidewinder ltx an my battery keeps drawing dead. I have checked most of my wires an the common rub spot under the fuse box an most grounds an nothing has rubbed through. I’ve tested the fuse box an it has power all the time even with key off. Iv unplugged the hood an makes no change there’s always power to the fuse box, an battery being drawn on. Sled starts an runs fine.. I’m stumped any info would be appreciated
Try pulling one fuse at a time with a test light between the Negative cable and the Negative of battery. When you pull the fuse in circuit with draw the light will go out. Should help narrow it down at least to the circuit the fuse is on.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
If you have a flasher plugged in unplug it.
Rayhall40
- Nov 1, 2022
- Cambridge ny
I believe every fuse has power when everything is off so maybe it something before the fuse fox. but I will try that later when I get home. An no tuner or flasher on the sled
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Any chance you have a garmin gps power cable hardwired to battery? I have found that they draw power when not being used. My father in laws dual sport would keep draining battery and we found that was the cause of it.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
I had the same problem on a Nytro with a Garmin power cable.Any chance you have a garmin gps power cable hardwired to battery? I have found that they draw power when not being used. My father in laws dual sport would keep draining battery and we found that was the cause of it.
Rayhall40
- Nov 1, 2022
- Cambridge ny
No gps. I pulled each fuse out an nothing changed still power to everything until I pull the battery fuse. Then there’s nothing to the other fuses.
You had the Negative cable off the battery and test light between it and neg batt post? 1 Inc 2000 asked if you have a flasher installed? Known battery drain.No gps. I pulled each fuse out an nothing changed still power to everything until I pull the battery fuse. Then there’s nothing to the other fuses.
Brod71
- Dec 24, 2022
- 2018 Yamaha sidewinder btx
I know it’s a bit late but I had the same problem with my 2018 btx. Nothing was pulling power but the dealership changed out the voltage relay and it has been good ever since. The relays in the 2018 aren’t the best quality for the cold temperaturesI’ve got an 18 Yamaha sidewinder ltx an my battery keeps drawing dead. I have checked most of my wires a the common rub spot under the fuse box a most grounds a nothing has rubbed through. I’ve tested the fuse box an it has power all the time even with key off. Iv unplugged the hood a makes no change there’s always power to the fuse box, a battery being drawn on. Sled starts an runs fine.. I’m stumped any info would be appreciated
