Pete_man26
Walked in the garage the other day and found 1/4cup of oil on the floor. Tore it apart lastnight to search for a leak, oil filter tight and no residue underneath the engine, looks like the foam attached to the front bulkhead that lies underneath part of the oil tank has absorbed oil. Oil looks to of run down the hose and dripped down at the bulkhead. Now is it the tank or the hose that is my problem?
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
My tank was cracked on the back side of the bottom front flange. Remove the tank and inspect.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Changed to used OEM tank today I got from Travis.
Travis I was heavy handed and one of the 2 smaller isolators broke - I'm guessing I'm not the first. Installed tank without the vibration dampeners. I don't miss the rear exhaust or the drone but the 4Cy sure sounds nice compared to my Winder.
actionjack
- Apr 9, 2005
IMO Because so many have had leaking hairline cracks in the oil tank this is the most likely cause of yours.Walked in the garage the other day and found 1/4cup of oil on the floor. Tore it apart lastnight to search for a leak, oil filter tight and no residue underneath the engine, looks like the foam attached to the front bulkhead that lies underneath part of the oil tank has absorbed oil. Oil looks to of run down the hose and dripped down at the bulkhead. Now is it the tank or the hose that is my problem?
RobX-1
- Coldwater, OH
From what I can dig up the older RX1's had an oil pickup with the recessed o-ring groove in the steel flange instead of the oil tank boss like the newer sleds, but it did not have a pickup screen tube.
That's odd because I could have swore the steel flange on my 03 RX-1 has the pickup screen tube.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
I was just going by the online fiche part numbers...That's odd because I could have swore the steel flange on my 03 RX-1 has the pickup screen tube.
Looks like the CFM Apex.RX1 oil tanks on Ebay now incorporate an o-ring anyhow, according to photos posted.
Problem solved.
actionjack
- Apr 9, 2005
Amusing. Kinda looks like your solution.I was just going by the online fiche part numbers...
Problem solved.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Yeah but probably machining an actual groove for the o-ring and not a just chamfer like I did.
bigbadbow
Just had same issue........my problem was K&N filter leaking from inside the welded on Hex?!?! Just a dribble but enough that I was losing 1 quart every 100 miles or so.......never gonna use K&N in my sled again.....too much work to get to the damn filter!
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Good to know, thanks for the heads up. Hard to beat the OEM Yamaha quality controlJust had same issue........my problem was K&N filter leaking from inside the welded on Hex?!?! Just a dribble but enough that I was losing 1 quart every 100 miles or so.......never gonna use K&N in my sled again.....too much work to get to the damn filter!
