RAMSOMAIR
Valve stems!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
There must be some inconsistency with mine, I don’t hear it when temps are warm. I had the sled running today to run some stabilizer through the fuel system and I didn’t hear the roll over valve.I was in cochrane last week and one day it was hovering around freezing and my sled was hot and it still did it constantly
ManhattanMike
- Jan 29, 2008
- Mokena, IL
- 2020 Sidewinder SRX LE, 2018 Snoscoot
I hear the valve on my 2020 SRX all the time, doesn’t seem to matter the temperature, but it is more pronounced when cold at first startup.It seems like it working for hellflyer, I guess it’s worth a try..
I will be adding the Pefi 250 tune with air box which doesn’t have the option to run the roll over valve hose into the air filter so I will be leave the hose in the belly pan.
Do you hear your roll over valve making that whopping noise? Mine is very loud at times.
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le,2021 mountain max le,2011 apex xtx,2012 arctic cat xf m8
I had the 2020 heated rov update done to my 17 sw and now can hear the sound guys are talking about .To me it is a good thing because if I hear that noise I know that the valve is venting and not frozen up.Temporarily vented to oil catch can and then back to original spot at boost tube to see if catch can works.
I can't say I've ever heard this noise on either of my sidewinders.
To those venting out the bottom. You may want it not too far from the exhaust as it will provide warmth to keep the end of hose from freezing over.
sab2022
- Feb 21, 2020
- Maine
- 2023 Sidewinder S-TX GT
ignore
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
like mine...725 miles and leaking...just need to come up with a permanent fix..I'm hopefulthank you. I know the stock factory seal on the tanks is just a matter of time before they leak.
I seal them correctly and make sure the rollover valve issue is addressed how ever you deem fit and never have a problem again.
