They control weight transfer/ski lift when accelerating.Oh, the black adjuster blocks that I think have 3 settings but 4 sides. When suspension compresses, this acts as a stopper , I believe.
When contact is made there, the front of the rear suspension should start to compress also.
shawnj
Ahh gotcha. So when it hits those blocks, front shock should start to compress?They control weight transfer/ski lift when accelerating.
These are also the blocks that sled is pretty much resting on. (For me) with no one on.
shawnj
I’m leaning toward week springs. Not sure if I can get a set before my week long trip next weekend. And if I do, do I get same spring or is there a heavier spring I should be using. My weight without gear probably around 215 lbs.They control weight transfer/ski lift when accelerating.
Probably will be better with next size stiffer.
The next size stiffer springs are the same thickness, they are just wound further.
shawnj
I’m about to google this now to see what I need. Wonder what stock is vs other options. Likely be hard pressed to get on time for me for my trip.Probably will be better with next size stiffer.
Big Boy springs
looking through previous posts I saw some confusion about yamaha and arctic cat cross reference number for springs. I can confirm that the yamaha big boy spring 8JX-G7474-10 is the same as Arctic Cat 1704-560. This is for the right side spring.
ty4stroke.com
shawnj
Big Boy springs
looking through previous posts I saw some confusion about yamaha and arctic cat cross reference number for springs. I can confirm that the yamaha big boy spring 8JX-G7474-10 is the same as Arctic Cat 1704-560. This is for the right side spring.ty4stroke.com
So this would be a step up from stock?Big Boy springs
I think the Cat number for left side is 1704-561So this would be a step up from stock?
Also, as per your first post, I wouldn't define 'bottomed out' as the rear arm touching the transfer blocks.
Just fyi.
shawnj
Interesting thought and clarification. I guess i figured if it was resting on the transfer blocks it was bottomed out, but understand bit better now, that not exactly the case, even though it feels like bottomed out when i step onto the sled LOL. Going to see if i can find the opposite side number now.I think the Cat number for left side is 1704-561
Just fyi.
It's in the link I posted.Interesting thought and clarification. I guess i figured if it was resting on the transfer blocks it was bottomed out, but understand bit better now, that not exactly the case, even though it feels like bottomed out when i step onto the sled LOL. Going to see if i can find the opposite side number now.
shawnj
Found them, see them on yamaha and arctic cat sites. Now just to find some locally and quick. Have you ever changed these? Just wondering, do i need to loosen track and just drop the springs one at a time? How difficult is that to do and get lined back up, if you know? Appreciate all the help and info, from you and everyone.It's in the link I posted.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
Just to be clear, you do have the triangle shaped torsion spring adjusters turned to the thickest point that the short end of the spring contacts? Correct?
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
You adjust it with the sparkplug socket.
shawnj
Yup, thickess portion and with spark plug socket. I could see sled try to raise when adjusting these as you mentioned but didnt help much. I read somewhere else that the front limiter strap might be causing rear to sag a bit. I have one hole left , i could try that i guess in the morning..You adjust it with the sparkplug socket.
RAMSOMAIR
Go all the way out with straps
- 31K
