RAMSOMAIR
That’s unfortunateI believe the GT models are the same ride height as the srx now. Same front dual rate springs and rear torsions are the same
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
That’s unfortunate
Why if the travel is the same?
RAMSOMAIR
The SRX SHOULD be the lowest fastest badassed leader of the troup
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I agree from a marketing perspective, it doesn't make sense to get them so closed together in specs.
RAMSOMAIR
However, I believe Yam/Cat should be more like the other 2 brands and have the availability of colour choices/tracks/etc.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I think the writing is on the wall that all Sidewinder models will likely feature EPS this season.
Shocks are a bummer although the regular QS3's work well. We need some more help in the shock game, Fox cant keep up with all the OEM demand (nobody can right now though). Seeing it on RMAX models as well.
Jvji24
- Mar 1, 2022
- Wi lakes
- Tcats
Polaris
I don’t know if they still are lowered or not? The 19 and 20s where and I don’t know if they went back to full height like the rest?
Compared to 17 and 18s the lowered 19 was significantly better in high speed cornering with the sled lowered.
I’m curious to see if the sidewinder is exactly the same now as the Tcat meaning clutches and gearing.
I agree that they need many more options
It’s nice to choose tracks and color options. Not everyone wants the same thing. I would go with a 1 inch 14 wide if available and most would not. Give us options and I think it helps sales.
Maybe
The eps sounds awesome and what I’ve heard it’s worth the extra cash
Maybe
RAMSOMAIR
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Lower than the SRX's.
RAMSOMAIR
yeah, dumb.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
The 19 SRX and Tcat were the lowest and IMHO the best handling and still rode very good.
RAMSOMAIR
Touche'The 19 SRX and Tcat were the lowest and IMHO the best handling and still rode very good.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
That SRX is a mean looking trail boss!20’ GT vs 19’ SRX
RAMSOMAIR
Thank you. It’s both quick and fast!
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Before doing an imaginary mic drop after posting on here with such confidence, you should think a little bit more, just a little bit. Nothing about the srx is light or classifies it as just a lake racer. It has an electronic suspension and a heated seat……clearly trail features. It uses different springs and nothing else to achieve a lower ride height and a 1” track which will mph better than a 1.25” track with all else being equal. The weight savings on the 1” track is moot because the heating elements in the seat combined with the switch to operate it and the module for the electronic suspension probably make it equal out lol. Some people like the look, lowered stance and are perfectly fine with a 1” track for the trails they ride. In fact, the 1” track gives up a little traction in corners and combined with a lower ride height you have a sled that corners real nice and flat. Odd that its only designed for straight line racing huh. Power steering does not have anything negative to this chassis. I agree it should be optional at purchase but its hard enough to get a sled now having it customized may only make things worse. Anyways, got to go. Im gonna get on my sidewinder xtx and hit the powder in a straightline and make sure I dont hit any hardpack. Its a 146 with a 1.6 track, musnt be deaigned for anything else right?Well the SRX is a lake racer not a trail machine.... buy a sidewinder!!!you don't need a SRX!!!IT IS A LAKE RACER,LOWER TO THE GROUND AND AS LIGHT AS POSSIBLE!!!!!THE SRX IS SUPPOSE TO GO STRAIGHT AND FAST,WE AR DONE HERE!!!
- 12K
