sideshowBob
The Garmin tread GPS trail dash mount and mountain sled mount[over goggle bag] has been available through Cat for a couple years now.
Makes a nice installation but I mounted mine on my handle bar bag so as not to interfere with my Razor belt temp gage.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
100% correct that there is nothing lightweight about a modern SRX or Tcat for that matter. Any Winder can be lowered using the SRX rear springs and screwing down the front shocks about an inch. I tried this on my 1100 and it worked great on the lake. It put the snow flap just about on the ground. After riding some rougher trails, I put the standard springs back in and decided to save them for racing if I become so inclined. If someone is worried about a few pounds due to the power steering unit and the heated seat, I would recommend exlax for a couple days before riding. That should lighten up the rider a few pounds. LOLBefore doing an imaginary mic drop after posting on here with such confidence, you should think a little bit more, just a little bit. Nothing about the srx is light or classifies it as just a lake racer. It has an electronic suspension and a heated seat……clearly trail features. It uses different springs and nothing else to achieve a lower ride height and a 1” track which will mph better than a 1.25” track with all else being equal. The weight savings on the 1” track is moot because the heating elements in the seat combined with the switch to operate it and the module for the electronic suspension probably make it equal out lol. Some people like the look, lowered stance and are perfectly fine with a 1” track for the trails they ride. In fact, the 1” track gives up a little traction in corners and combined with a lower ride height you have a sled that corners real nice and flat. Odd that its only designed for straight line racing huh. Power steering does not have anything negative to this chassis. I agree it should be optional at purchase but its hard enough to get a sled now having it customized may only make things worse. Anyways, got to go. Im gonna get on my sidewinder xtx and hit the powder in a straightline and make sure I dont hit any hardpack. Its a 146 with a 1.6 track, musnt be deaigned for anything else right?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Yeah I think you're right. In that case it will be easy to make my 22GT into a 2023. I'm not a super big fan of the decals in 22 but this 23 looks good!I know this is the LE, but it looks like a 2022 LTX GT with different graphics. It has the same dark blue plastic.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Am I wrong in saying that the heritage colours of the SRX are white/red/gold ?
earthling
SRX the storybook ..
The history in my words: SRX is a true legend! S = Sport R = Racing X = Xperimental motor code RT = Racetuned L/C = Liqued cooled: 1976 to 1977: RX 1978 til 1980: RT439 L/C standard bore: 68,5 mm 1981 (EUR): RT439 L/C standard bore: 68,5 mm 1981 (US/CAN): RT437 L/C standard bore: 66 mm...
totallyamaha.net
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Great read .SRX the storybook ..
The history in my words: SRX is a true legend! S = Sport R = Racing X = Xperimental motor code RT = Racetuned L/C = Liqued cooled: 1976 to 1977: RX 1978 til 1980: RT439 L/C standard bore: 68,5 mm 1981 (EUR): RT439 L/C standard bore: 68,5 mm 1981 (US/CAN): RT437 L/C standard bore: 66 mm...totallyamaha.net
My start as a Yamaha enthusiast was on a 82 SRV .
I have never to this day owned a blue Yamaha sled .
Blue is a slow colour !
Can't imagine how much faster those SRX's of the 2000 +/- era could have been if they were red / White and Gold !!!
Like my 22 SRX !
earthling
Great read .
Like my 22 SRX !
But they are nice looking! We should go ride sometime..
Lets see those sidewinders!!
As the season is coming to an end, lets see some sled porn!
ty4stroke.com
stgdz
- Mar 27, 2021
- Buffalo MN
So has anyone looked into putting eps in our pre 22's?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
It will be an expensive project. You need the steering box, new wiring harness, steering shaft and brackets. PLUS THE ECU which adds to the cost since the steering is speed sensitive. I figure about $3-4kSo has anyone looked into putting eps in our pre 22's?
number1kyster
It would be a lot cheaper to go with an MPS kit.
sledding rocks
darv
- Aug 9, 2005
- 08 Apex 40th LTX
there is a comp who makes a power steering kit it is like 1500.00It will be an expensive project. You need the steering box, new wiring harness, steering shaft and brackets. PLUS THE ECU which adds to the cost since the steering is speed sensitive. I figure about $3-4k
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I dont see the power steering decal. Maybe someone can show us where it is at.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
There is the GSE kit but it introduces a lot of steering play and is always active. The factory one fades away at speed.there is a comp who makes a power steering kit it is like 1500.00
To me the factory one is the only option that works well.
Fast
- Sep 25, 2018
Well the srx is the most superior trail sled available it corners like its on rails can't imagine anything better obviously your not a trail rider or you would know thisWell the SRX is a lake racer not a trail machine.... buy a sidewinder!!!you don't need a SRX!!!IT IS A LAKE RACER,LOWER TO THE GROUND AND AS LIGHT AS POSSIBLE!!!!!THE SRX IS SUPPOSE TO GO STRAIGHT AND FAST,WE AR DONE HERE!!!
