23 TOP GEAR FEEDBACK
scherbs
S.E. MICHIGAN
Website
home.comcast.net
I purchased a 2007 Apex GT at the end of last season and put 500 miles on it before the snow thinned out. I have started to prep for this season, and have changed the top drive gear to a 23 tooth. I am looking for feed back from others who have done this gear change. Do rpm`s change dramatically anywhere in the powerband? Will I need to consider a clutching change, and if so what? I did install 192 studs. They are placed on both sides of the rails for hook up. The mono spring has been upgraded for my weight. I weigh about 270 with my gear on. Thanks in advance!
No needs for clutching here,i swap mine last year ( after i put a aftermarket clutch kit ) but my rpm stay the same 10600 rpm.After the gear change i never look back,this is a mod that you can feel from 0 to top end out of the garage wen you made the swap and all across the power band,no top end lost.Enjoy!
ROCKRTX
By dropping the top tooth to a 23 you noticed increased performance throughout the powerband? Is that correct? I was thinking of making the same change to my 2007 ATTAK bought at the end of last season as well. Will the 23 be an applicable change for the ATTAK? I am not sure how the gearing compares on the two sleds.
Thanks for the input guys.
Shane. I believe the Attack comes with the 23 top gear. You may need to go to a 22 top gear. I think you would be alright with the stock chain, but not sure.
Thanks for the input Scherbs. Anyone know for certain? I appreciate everyone's assistance. :rocks:
Attak come stock with 23. You'll need a 22 top, or a 40 bottom reverse gear to gear down.
With a 22 top gear you will need a new chain (68 link) but with the 40 bottom gear you can use the OEM chain.
I have them in stock for $35 + shipping.
I am going through this gearing issue with my Attak.. I just put a 144 kit on it, Thinking of going 23/40, lazy basdard thought 22/40 should be close. Any thoughts?
I'm going with 23/40 on my RTX. On snow, my sled couldn't pull the 24/40 that was in it (peak MPH). On ice was a different story.
