jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Lots more vibration on the generator?i dont think it will pop out , if anything i think it would cut the wall of the grommet makin it 2 pieces , then that would be not good! i only think this because i added a gerry can tank to my gas generator and put this exact fitting in the bottom on the jerry can to gravity into the extenda run cap on the generator, and it split after a few weeks, i then put a bulkhead style fitting in it compatible with fuel much better , but there is no room to use that style on the winder
Guy could replace the grommet every year for under a buck?
HABS 1
- Oct 22, 2015
- corunna,ontario
haha true! no vibration, it was installed on the reserve tank , on the sled i actually used the gromet in the top of tank the return did go to and used the gromet i ordered to put back up top n plug, hoping the stock gromet was better quality, that rubber grommet woukd be the only weak link imo but i did it anyway cause seems nobody had problems, just be nice to use a better fitting but limited space
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Better grommet?haha true! no vibration, it was installed on the reserve tank , on the sled i actually used the gromet in the top of tank the return did go to and used the gromet i ordered to put back up top n plug, hoping the stock gromet was better quality, that rubber grommet woukd be the only weak link imo but i did it anyway cause seems nobody had problems, just be nice to use a better fitting but limited space
Viton Fuel Tank Grommet - Wicks Aircraft Parts
Self sealing grommet for use with tank mount valves and elbow fitting. Made of Viton for superior fuel resistance and compatibility. Requires 33/64" mounting hole. Fits FV- 11046 and the FV-11032 and is required for installation.
HABS 1
- Oct 22, 2015
- corunna,ontario
forsure looks like a better one then i have! hopefully its fine n lasts , like u say its cheap as long as it don't decide crack /break/ cut on trail! im confident it should be good because others have had luck time will tell i guess
Better grommet?
Self sealing grommet for use with tank mount valves and elbow fitting. Made of Viton for superior fuel resistance and compatibility. Requires 33/64" mounting hole. Fits FV- 11046 and the FV-11032 and is required for installation.www.wicksaircraft.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I understand the apprehension on this grommet and it coming unbuttoned.. If you drill the hole of correct diameter 1/2" and your fuel tank vent is not blocked your good.. I had this EXACT feeling a few years ago, but after a few thousand miles it went away. I'm going to try this grommet I linked and just change it every year as wear item. I switched over to the metal 5/16 elbow but I cut it slightly shorter where it hangs into fuel basket. Its the same as the plastic in dimensions(now) only that its a 5/16 elbow . Ran thousands of miles with the plastic elbow with 1/4" fuel line.. I switched it out as I went up a tune and installed bigger fuel pump.forsure looks like a better one then i have! hopefully its fine n lasts , like u say its cheap as long as it don't decide crack /break/ cut on trail! im confident it should be good because others have had luck time will tell i guess
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Did you guys get this item?FYI - Same price (and same free shipping) over at their site Boost Kinetics (https://boostkinetics.com/shop/ols/...0-998t-external-fuel-pump-harness-relay-turbo). Ordered mine yesterday.
I ordered one in the end of November and have not received it yet.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Email him….he got right back to me and he builds them to order. Got mine within 10 days.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Got mine but took 10 days or so. I would call or email.Did you guys get this item?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Yes, I got mine within around a week... but I am also only about 2.5 hours away from him.Did you guys get this item?
Fords4life
- Dec 7, 2021
- South Dakota
Same here about 10 days from order time, well made, looks like a factory item, plug and play.
Turboflash
- Mar 18, 2019
- Southern MN
I got my 3 but it took almost a month.Did you guys get this item?
Turboflash
- Mar 18, 2019
- Southern MN
Text Doug at 989-225-1545Did you guys get this item?
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Same thing happened to me. Called him and he said he had some problems with the website and lost some orders. Called him last Sunday and had mine by WednesdayDid you guys get this item?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Found out Same thing happened with my order after a phone conversation.Same thing happened to me. Called him and he said he had some problems with the website and lost some orders. Called him last Sunday and had mine by Wednesday
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
took 10 days for mine
