eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I'll take a screen cap tonight to see the exact naming convention I have loaded, but in the meantime the "search" feature here is your friend, ;-)
https://ty4stroke.com/threads/popul...n-tune-revisited-feb-4th.152219/#post-1415843
Thanks... Spoke with TD today and they said their is not a specific tune for a 3" exhaust. Its either "stock" exhaust or "modified" exhaust.... which is for 2.5 or 3" systems....
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
I believe Hurricane is the same way. They don't have different ones for a Cold Air Intake either.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Yeah... I’m gonna hook up a Wideband and see what the hell is going on. I shouldn’t have to run octane boost on a 270 pump gas tune. My friends with 3” Sandale trail exhaust don’t. Just want my Winder to stop knocking before I do damage....
- Sauk Prairie, WI
- www.ty4stroke.com
TD tune?Yeah... I’m gonna hook up a Wideband and see what the hell is going on. I shouldn’t have to run octane boost on a 270 pump gas tune. My friends with 3” Sandale trail exhaust don’t. Just want my Winder to stop knocking before I do damage....
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
TD tune?
Yes
- Sauk Prairie, WI
- www.ty4stroke.com
You positive you have good fresh 91 octane minimum?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Running 93 octane.
- Sauk Prairie, WI
- www.ty4stroke.com
Holy! Air leak somewhere?Running 93 octane.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
No. Running a CAI. Checked all the connections the other day.
- Sauk Prairie, WI
- www.ty4stroke.com
Hmmm, something is goofy. 93 should be more than enough with that tune. For shits and giggles did you try some higher octane fuel or a shot of Torco? Do your buds have the same tune?No. Running a CAI. Checked all the connections the other day.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Not yet. I will splash some C16 in there to try and troubleshoot a bad sensor. My buddies have the same tune but not the Heartbreaker exhaust. Just the normal 3” Sandale exhaust. That’s the only difference.Hmmm, something is goofy. 93 should be more than enough with that tune. For shits and giggles did you try some higher octane fuel or a shot of Torco? Do your buds have the same tune?
- Sauk Prairie, WI
- www.ty4stroke.com
Do you have a boost gauge? You could have an over booster?No. Running a CAI. Checked all the connections the other day.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I do. Seeing 16.5 on stock BOV and 17.5 on TS BOV.
Have you talked with Dave about it? Might want to check out this older thread....
https://ty4stroke.com/threads/sandale-3inch-with-hurricane-tunes-update.151317/
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Meet the Outlaw 1.0, 3.5inch! Makes more power then the HyperFlow and is quieter then all 3inch mufflers mentioned in this thread. It's unique design allows for maximum flow at a nice mellow sound. These are a limited production, not many left!
- 14K
- 10K
