5000kms anything to go over?
savageman69
Canada
2014 arctic cat zr 7000 limited
seasons over for me what should i be digging into at 5000kms to look at?
Thinking of dropping iridium plugs in it? worth it or?
hoping evo ecu flash and exhaust and intake as well.
Also on my list
bdx brake disc
maybe rr track shaft
tri hub replacement
thanks guys
Also on my list
bdx brake disc
tri hub replacement
thanks guys
last trail run for us tomorrow then we will have to trailer north to my camp!
evo reflash;)! I'm interested too!!
sandale exhsaust
i cant decide on exhaust to many to choose from lol....im hoping they hold to their word to bring a 87 octane map id like to keep it not requiring premium
Excell intake rocks. It not only increases Hp It also stop loss of HP when riding in the powder. Before I put it on my front intake would plug full of snow because of my bumper and loose power.
you have any clutching done?? thinking of playing with wife's 7000
excells clutch kit using the existing clutch components works awesome. They provide you with everything you need to change to the 8dn and different weight in your weights. Well worth the $$$$$$. It includes the belt.
this is for the cat version(cat clutches are different)
Cat clutches are different. They do have a kit for the cat, but not sure how it compares. Call them and ask Aaron About it. He knows his stuff. I even asked him about a header and he said there is no point in putting one on, you will not gain anything.
no i havent touched the clutches at all...other then recall heavier weights im impressed with the clutching so far actually but once ecu/exhaust and intake i will need to do it for sure
Check your tri hub. Mine have out on the weekend after 2600km's
ive been checking it all the bearings appear to have stayed tight...it will be removed now anyway but it held up the bolts came loose tho near the end of this season however
Check all bearing in clutch and bushings. I had a friend end his trip with both bearing and bushings gone. I will be doing this as a yearly maintenance as I put on many miles.
Have you been running Cats, if you have we should be asking you about the suspension side. As far as the motor, change oil and everything else should be good.
While the oil is drained open your chain case and have a look, WATCH that washer on the end of the reverse gear shaft, if all is good in there put in fresh oil there as well.
Grease the clutch side Brg. as well as the track drive shaft Brg.
If all your Brg's are good, fresh oil, fresh belt, life should be good for another trouble free season.
i have the suspension set the way i like now...torsion springs on 2 and the front track shock about 1 inch spun up and floats at 75 lbs . However my sleds in the shop right it appears the oil tank is leaking out a crack in the tab, clearly it either took a bump or when they replaced the cracked chain case cover they snugged it up to much. Makes me pretty nervous about messing with it. Also my one float seem to have lost air a couple times so im getting those checked and what not as the warranty is over now in a week or so.
I plan to check all the bearings and stuff...sliders look like new but im cautions may replace anyway.
Anyone have input on iridium plugs? any gain in doing it? idle or better starting?
