Allan
I don't think the 16.5 has it as listed in the 16.5 updates?17 removed it. It went away with Sidewinder.
https://ty4stroke.com/attachments/2016-spec-8-pdf.111166/
Just went to clips and a wobble without the taper lock. There was 2 wobbles. Early and late. 17 went 6206. No wobble.I don't think the 16.5 has it as listed in the 16.5 updates?
SnoBird888
good read! glad i have the 2016 I guess.
Who is going to be first to try to upgrade to the 17 parts?
johan
I'm going to switch out the wobble bearing to a standard 4206 skf bearing I have 270+hp in my sled, the 16 secondary shaft is holding
Please let us know how it goes. What parts are needed etc. Thanks!I'm going to switch out the wobble bearing to a standard 4206 skf bearing I have 270+hp in my sled, the 16 secondary shaft is holding
johan
Will do but as I understand it is just replace the bearing but I go a check if we need to do something more
Notice area in red is different length in pic. This is only reason I am unsure its just bearing change.Will do but as I understand it is just replace the bearing but I go a check if we need to do something more
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
So what are options for 14-15 guys?
I know we can install 16 updated newer stuff or now the 17 if it works,
Is there some bearings we can upgrade to? I was reading that some guy found a better skf bearing that seems to be a bit stronger then factory.
yammitrip1
- Sep 28, 2017
- Rome ny
I think he saying he is going to try a different bearing , member the newer one is 6206, he said 4206 unless it was a mistakeNotice area in red is different length in pic. This is only reason I am unsure its just bearing change.
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
Will look into the 2017 parts when I get that far in a week or so.Who is going to be first to try to upgrade to the 17 parts?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Any updates on this? I’m in there now and thinking I’d like to upgrade to 17 shaft but want to make sure all I need is a new shaft and 6202 bearing.
x2 Who did it?Any updates on this? I’m in there now and thinking I’d like to upgrade to 17 shaft but want to make sure all I need is a new shaft and 6202 bearing.
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Looks like the bearing housing has a different part number and price...2015 and 16 part # 8JP-G7631-00-00
2017 part # 8JP-G7631-10-00...same bearing though.
ski
- Feb 7, 2006
- Manitoba Canada
- 2015 Yamaha Viper R-TX LE
Any reason you replaced the complete assembly rather than just the jackshaft? It's quite a cost difference. I looking at updating my 2015 since I have it apart to put reverse back in it anyway.Start with Parts list for 16 Jackshaft Update. Number 16 and 17 are reverse order in this diagram. Washer Goes Against Gear! Snapring goes on first.
View attachment 117805 View attachment 117806
