Higher degrees = more backpressure =more rpms.
But in general you control RPMS with primary weights,not secondary. While the secondary pressure and helix angles will change RPMS some, you want to set the rpms via primary weights.
More backpressure more belt squeeze, LESS slip, more heat.
Less backpressure MAY cause more slip and in turn also cause heat.
Its a tight-rope walk of balance.....to get the best setup.
Gates and other softer belts can use less backpressure, as they dont slip as easy.
Im going to try 8DN again as I have had good luck with them.
