putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Check this out he is a Ty Member. http://yamaheater.com/Products.php smart supply works great.
Anybody know which one is the correct Smart Supply for the Viper on the Order Page on Yamaheater's website?
Nice find!Depending on how much underside clearance there is opposite the tether this one would be a no solder solution F to F adapter:
http://www.ramelectronics.net/product.aspx?zpid=2955
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
I like the rca on bars. Good anchor for holding plug when you forget to unplug and rip it apart walking away. And you will forget
X2
I do also but no long enough cord available.
I know but other things to work on. If cord was longer I would have put it on bars. Pretty much threw this cord on and went riding. Worked fine all season.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Heres what i did.
I wanted the cord up on the bars so i Bought the skidoo heated shield wiring kit.
Drilled a hole in my plastic/rubber bar cover. Mounted the kit.
Then ran the wiring back direct to the battery with a 3 amp inline fuse.
I wanted the cord always powered/live, but you could easily just run it to the accessory wire ac/yamaha provides down by the chaincase.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I like to run the E- shield cord under the coats outer zipper so never catches on anything then Plug in to the cord at the base of the steering post or as the guys have shown on this new sled will be on the Rt side of the Gas tank area. Should work great will need to secure so when pulls off - it wlll as in the position I described you never see or feel the cord so you get off. and it pulls loose.
Mark
Mark
Here is the little clip I used to hold the cord. Little alcohol to clean area and stick it on it will not come off. These are a good idea to use on helmet also to avoid ripping plug out of shield on that end.
Thanks for posting that Cannondale. I had never seen one of those. Not a bad idea!
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
Thanks for the info on this connection. I installed the RCA to this 2 prong connector cable and am all set to go with the RCA jack just sticking out under the right side panel under the bars. I'm wondering what load that connection can handle. I plan to run a heated shield, plus an I-phone to be used as a NAV plugged into the cig lighter connection via a USB adapter. Are these 2 circuits tied together, if so looking for amp load max for the circuit.
Thanks, Reb
Thanks, Reb
View attachment 99020 Maybe this is it. Little black rectangle plug on bottom of pic. What do you do why the end you remove?
Look for the fuses and see what they are. Might be in manual. I believe you will be fine though.
wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
I extended the wire up to the left bars and hard mounted the rca. I have found that the hard mount where I can get to it with my left hand comes in handy. Many times we will take off and I forgot to plug in, or just want access while moving.
The hard mounts on the new Pantera are nice I have one on order. Nice rubber cover is on them also.
Do tell please.
