Turboflash
- Mar 18, 2019
- Southern MN
Need lots of heat to get Allen bolts out.
Fords4life
- Dec 7, 2021
- South Dakota
Yes spider is a tight fit into center "hub" after bolts are removed, light tap from a hammer will free it.Youre the second guy ive heard that says the spider comes right out after taking the 6 bolts out. I did this and that sucker is not coming off.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I'm seeing lots of problems even with Cats new Adapt. Why can't Cat seem to build a clutch that doesn't explode or fail in dramatic fashion? I've seen more photos now with exploded Adapts and we don't even need to talk about all the TEAM primaries. How is it a clutch like the PB80 can hold up well but Cats new Adapt can't? If Cat is going to survive they need to find a better clutch manufacturer.
Fords4life
- Dec 7, 2021
- South Dakota
I have a new adapt comming from country cat as i write this, this "new" one has been superceded by two or three part numbers, looks like it will be like the "improved" 8000 with steel spider and heavy cover with dowl pin locaters...fingers crossed cause the previous two adapts have been plain crap!!!!!I'm seeing lots of problems even with Cats new Adapt. Why can't Cat seem to build a clutch that doesn't explode or fail in dramatic fashion? I've seen more photos now with exploded Adapts and we don't even need to talk about all the TEAM primaries. How is it a clutch like the PB80 can hold up well but Cats new Adapt can't? If Cat is going to survive they need to find a better clutch manufacturer.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I thought about getting one of those "new" ones for a back up. They are priced pretty reasonable I thought.I have a new adapt comming from country cat as i write this, this "new" one has been superceded by two or three part numbers, looks like it will be like the "improved" 8000 with steel spider and heavy cover with dowl pin locaters...fingers crossed cause the previous two adapts have been plain crap!!!!!
Fords4life
- Dec 7, 2021
- South Dakota
Yes sir $389 but no wieghts or pins, i like the adapt so hopefully its all sorted out now, have my cat set up tapp back on for now.I thought about getting one of those "new" ones for a back up. They are priced pretty reasonable I thought.
- 30K
- 21K
