- Apr 14, 2003
- Hessel, Michigan
Very good. Have tried a different helix yet and is your secondary 6/1? Poor snow flap !!!!
Haven't received my helix yet.....next step is pulling the secondary off of my Nytro and going with some helix's I have for the older clutch to see what angles are needed.
My secondary is still stock and stock setting
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Put the first 200 miles on the BTX LE over the weekend. All stock except Thunder products clutch kit. 8650-8800 rpm with very cool clutch temps. Awesome pull compared to stock setup. Had another exact sled there that was completely stock and there was a noticeable difference. We both rode both sleds and had the same opinion. Gained 2-3 sled lengths over stock in a short run.
WINDER1987
Does Anyone know the torque specs on the primary and secondary bolts?
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Here you go.........Does Anyone know the torque specs on the primary and secondary bolts?
http://ty4stroke.com/threads/check-...new-specs-108-back-off-then-43-ft-lbs.144913/
WINDER1987
Thanks any info on the secondary ?
VX1R
- Sep 19, 2004
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1986 Inviter
You must have missed the secondary torque specs on the link........it's 43 ft. lbs.Thanks any info on the secondary ?
It's a single stage torque value on the secondary unlike the primary. Just torque your secondary bolt to 43 and you're good to go.
WINDER1987
Oh ok thanks ya I did miss that I just got my clutch kit and have a D&d exhaust how does this setup look to everyone going to install it tonight if everything looks goodYou must have missed the secondary torque specs on the link........it's 43 ft. lbs.
#1 hole where the dowl goes takes the 3/4" cap screw.
#2 is the 3/8 aluminum bolt and the #1 is the 3/8 steel bolt and 1 Thick washer.
shagman
Vendor
- Feb 18, 2014
Yes on the kit setup. But 3/4 set screw in #1. Careful with the can of you don't have a tune this sled will lean out with a can and no fuel adjustments.
WINDER1987
Sorry I do have the 3/4" set screw in. And as far as exhaust goes D&d told me i was fine to run it with nothing that's a 15hp gain but if I remove the insert it gets louder and a 25hp gain but I would need a fuel controller then. What do I need for a fuel controller ?Yes on the kit setup. But 3/4 set screw in #1. Careful with the can of you don't have a tune this sled will lean out with a can and no fuel adjustments.
shagman
Vendor
- Feb 18, 2014
If your running their can ( D & D ) I would use what they recommend.
WINDER1987
Thanks ya they recommend only running or needing a fuel controller if you remove the insert which I have not removedIf your running their can ( D & D ) I would use what they recommend.
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Following....
Sent from my iPhone using Tapatalk Pro
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Stock output LTX LE do I need to add anything to the TP kit or run as set up?
Looks like it is set up as follows
3/4" allen in heel
3/8" Aluminum in the middle
3/8" Steel with 1 Thin washer
Sent from my SM-G920W8 using Tapatalk
3/4" allen in heel
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
Have you tested or heard anything on how the ullmer clutch setups are working?
krm
- Apr 22, 2016
- ny
add another 1/4 "allen in the heal ,2 thin washers in the middle and and 1 thick washer on the tipStock output LTX LE do I need to add anything to the TP kit or run as set up?
3/4" allen in heel
