SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
Maybe? We did ~350 miles on Saturday. I was riding with an 1100 Turbo with obnoxious exhaust and a viper both all blacked out. We did run through Marquette on Friday night on our way up but headed east to Sault Ste. Marie and back on Saturday.Were you at the Jack Pine lodge on Saturday?
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
Googling Jack Pine, No we didn't stop there. Blew past that area around 1am Sunday morning getting back.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm up North for the week on the high speed trails and seen this post and was concerned about heat with my header. Well after running 100 miles at good speeds I can say that with the added vents I don't have concerns with heat. I removed the side panel and the gas tank actually felt cool in proximity to the header. I did wrap the complete front of the gas tank with heat tape. I did notice that my stock heat shield is all cracked at the mounts. I highly recommend the mo flo vents.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I have the knee pads where your vents are.
I replaced my upper heat shield this year. Same thing, it cracked around the mounting holes.
Picked up one of the left over kits from when they had the updated shields for the 17 models.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Part number for upper heated shield kit.
DMCTurbo
- Nov 12, 2005
Thank you, I'm not sure if mine was ever upgraded. Was it a recall by chance?Part number for upper heated shield kit.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I dont remember if it was a recall, Maybe.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
I have the exact same vent kit both front and back.I'm up North for the week on the high speed trails and seen this post and was concerned about heat with my header. Well after running 100 miles at good speeds I can say that with the added vents I don't have concerns with heat. I removed the side panel and the gas tank actually felt cool in proximity to the header. I did wrap the complete front of the gas tank with heat tape. I did notice that my stock heat shield is all cracked at the mounts. I highly recommend the mo flo vents.
This is the best picture I have of the venting.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I rode with someone who had a header and a wrap last year!
That MS16 Header tune rocked for sure, but it smelled more then a 2 smoke for the whole season. Bad enough, that when he was leading, I purposely stayed further behind because of stinging eyes. Man that titanium wrap stunk, and when the header cracked and turned the wrap into underhood debris, it really really stunk and made a mess to boot!
Either way, that header, stock or aftermarket, is scary close to the plastic gas tank, so you better stay on top of those, (Or Else)!
Dam incredible just how hot the entire entire exhaust system gets, even on a bone stock Winder when cruising at 80 and up for long distances!
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
the wrap does not work on the stainless headers, every one ive seen wrap has cracked due to holding to much heat in. just the good venting and stock shield work best. i also put the stingray clutch shield behind sec to stop the heat from header making sec hot. just put the extra heat wrap on gas tank , hose to exchanger and inner right side panel and your good. i have tomcats turbo blanket on under stoch turbo shield aswell
21GT
- Mar 3, 2021
- Michigan
- 21 Ltx-gt
Would you by any chance have the part # for the frog skin you used to cover up the holes?The plastic area between the factory frog skin vents i opened up and installed frog skin material to allow more air flow thru the secondary intercooler. Brings in huge amounts of cooler air under the hood.
I didnt take a picture with the screen installed.
View attachment 166644View attachment 166645
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I bought a bulk screen made by slp and bought some lexan and made my own screen.
Slp powder filter 13 3/8 × 7 1/4". Part number is 14-160 also has a WPS part number 59-7267.
First time using this brand.
Not mine. But happened in VT on the rail trail.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Be careful with that Stingray heat shield it’s restricts air flow to the header tank area. Not goodthe wrap does not work on the stainless headers, every one ive seen wrap has cracked due to holding to much heat in. just the good venting and stock shield work best. i also put the stingray clutch shield behind sec to stop the heat from header making sec hot. just put the extra heat wrap on gas tank , hose to exchanger and inner right side panel and your good. i have tomcats turbo blanket on under stoch turbo shield aswell
