tator
can the evo flash be redone? i have the hurricane 190 kit. if i did the high compression turbo flash then in 2 years decide to do caves 240 kit can the ECU be reflashed for the low compression setup?
- Apr 14, 2003
- Hessel, Michigan
I believe I asked Jim from EVO this very question and he said the ECU can be re-flashed over and over....and if you went to a more expensive stage performance, you would only have to pay the difference.
But check with EVO to see what exact pricing would be
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Stage 2 for now, then If I get bored, upgrade to stage 4 for only $80, that would be nice.I believe I asked Jim from EVO this very question and he said the ECU can be re-flashed over and over....and if you went to a more expensive stage performance, you would only have to pay the difference.
- Apr 14, 2003
- Hessel, Michigan
Yup, I believe that is what Jim said in earlier posts when the flash came out.
