Rove44
does anyone know what number tooth gear is on the bottom i was told if i went one bigger i would get a little more pull. Just not sure what gear to buy
Rove44
somebody must know this.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Rove,
You can usually find what you need by using the search function. Here is a good thread on gearing.
http://www.ty4stroke.com/viewtopic.php? ... ar&start=0
Instead of increasing the lower gear by one tooth I reduced the top gear by one tooth which has a greater effect and the top gear is less expensive to change.
07 GT
The bottom gear on an apex is 38 tooth. The top gear is 24 tooth. Which equals a 1.58 gear ratio.
By changing the top gear to a 23 tooth, you gear ratio would be 1.65.
BTW on the Attak the top gear is 23 tooth already.
sniperviper
22/38 on 07 - 08 and probebly 09 apex rtx
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
sniperviper said:22/38 on 07 - 08 and probebly 09 apex rtx
Not sure if you guys in Norway get something different but here in the US our Apex is 24/38 for short track and 23/38 for the long track.
BigMac
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Blue Dave said:sniperviper said:22/38 on 07 - 08 and probebly 09 apex rtx
Blue Dave
Apex RTX 24/38 '06
Apex RTX 22/38 '07-'09
Attak 23/38 all years
Apex GT and ER 24/38 all years
rxrider
SledFreak
- Feb 7, 2005
- Ontario. Canada
rxrider said:Blue Dave said:sniperviper said:22/38 on 07 - 08 and probebly 09 apex rtx
Blue Dave
Apex RTX 24/38 '06
rxrider
This is correct..
Shivesy
If you go the next size bigger on the bottom it would be a 40 tooth.
LazyBastard
Only if you have a problem with addition though... 38+1=39.
Shivesy
Do they make a 39 in reverse?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Yes they do
Part#s for a '06 Apex ER
2 8FB-47587-80-00 SPROCKET, CHAIN DRIVEN (38T) UR 1
2 8FB-47587-90-00 SPROCKET, CHAIN DRIVEN (39T) UR 1
2 8FB-47587-00-00 SPROCKET, CHAIN DRIVEN (40T) UR 1
Lammy
So I just got an 06 RTX, would it be beneficial to go to a 23? Kinda sounds like it. I'd loose a little top end (not that I care), but gain a little bottom, and mid? Correct? The smaller the top gear, the more bottom end, correct? And is the 23 kinda a comfy medium then? Or just kinda works better in general?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Yes you are correct, even a 22 would do fine but then you would have to change the chain as well, from a 70 link to a 68 link. With a 23 top gear you would NOT have to change the chain.
