SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
im by no means a great wrench but I followed these directions and completed this job in a few hours. Honestly the worst part is getting the air box back on and the clamps to cooperate . Great directions appreciate them. Next time it will be half the time.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
WD-40 on the boots and they slip right back on and get a set of ball end Allen sockets with the long stems and the clamps become a breeze too.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
silicone spray works for me.
SAB1
- Mar 1, 2011
- Tuftonboro NH
2010 Vector GT
2006 Apex
Correct I used WD40 and had the ball end wrenches which helped a ton. I just had one of the rubber covers that just didn't want to stay on when I tightened it down it (the clamp) would come off the rubber boot. What I ended up doing was wiping off excess WD that worked it way under the clamp and then tightening each of them little at a time and then moving to the next rotating thru that sequence a few times and it held.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I've never lubed the boots, they slide right on. I don't have a ball end set of long allens I just a standard long set I picked up somewhere. For the oil plug I use a 3/8th drive and a socket allen
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Charley you can get by with this because of your small delicate hands that can fit in places where others can't LOL
I decided NOT to say anything about never having a 'ball end set'. Nope would not touch that one.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Thats why I went with Sasquatch so as to hide the delicate side of me!
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
jagabom
I also turn the black rubber intake boots a little to make the Allen head bolt closer to the top.
Jim
Jim
RobX-1
- Coldwater, OH
If I'm not mistaken, at least on my 08 Apex, not only is there a notch for the hose clamp to position correctly, but I also thought there was a notch on the air box for the intake boots to be positioned correctly. I currently have the air box off and will have to confirm this when I get home tonight
SAB1
- Mar 1, 2011
- Tuftonboro NH
2010 Vector GT
2006 Apex
Yes there is a spot in the clamp where a little rubber tab on the boot fits in to align it.
RobX-1
- Coldwater, OH
Correct, but I also thought there was a tab on the air box where the rubber boot is suppose to fit into. My comment was in reference to jagabom spinning the boots so that the allen head bolt on the clamp is closer to the top. Just as I thought the clamp needs to be aligned with the rubber tab on the boot, the boot needs to be aligned to the tap on the air box. Again, I could be wrong and will check but wanted to throw caution to re-positioning the boots.
RobX-1
- Coldwater, OH
Here's the notch on the air box I was referring. Whether or not there would be an issue spinning the boot to orient the clamp bolt closer to the top remains to be seen but I was fairly certain there was one. Although Yamaha probably had a good reason to put that notch there, I'm not really sure there would be problem with rotating the boot like jagabom had done.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
with the right tool there is no need to rotate them so I never did.
jagabom
ThanksRobX-1. Didn't know that.. I also don't know if the 1/8 of so of a turn will cause any problems. For my easy riding style, i don't think so.
Jim
08 APEX
Jim
08 APEX
- 24K
