number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
The cats have a plastic tensioner wear block which has saved you from failures, it will compress/wear and not allow for the chain to be over tight for any length in time. The roller is unforgiving in the yamaha case and if too tight will create a lot of stress, ruining bushings and chains.
Is there any reason why we can't use the old chain tensioner on our Sidewinders?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
No . Just need the parts and a way to seal the hole in the case.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Sealing hole is no issue.No . Just need the parts and a way to seal the hole in the case.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I wouldn’t use the auto junk tensioner from way back, I would use the zr9000 manual tensioner, it will still utilize the hole and tensioning bolt.Is there any reason why we can't use the old chain tensioner on our Sidewinders?
Actually I’m not going to run either of those, sticking with the yamaha roller properly set to 1.5 turns out and done.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Actually 3/8 npt tap it and run a hose up for easy filling of this POS.
Gotta remove the reverse actuator to fill the dam thing... BS I say!
What’s next? Fill your engine oil through the PCV valve?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Lol. Take it easy! Let’s get out fishing ? I got a 90 Yamaha vmax SHO that will ease your tension? Purrs like a kitten? Wait I mean like a Yamaha shouldActually 3/8 npt tap it and run a hose up for easy filling of this POS.
Fast
- Sep 25, 2018
X2The cats have a plastic tensioner wear block which has saved you from failures, it will compress/wear and not allow for the chain to be over tight for any length in time. The roller is unforgiving in the yamaha case and if too tight will create a lot of stress, ruining bushings and chains.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
get back to the post,its not a chaincase post
