vipermike2002
- Jan 19, 2006
- Barrington, IL / Rhinelander, WI
- 07 Attak
I hear a clunking coming from my rear suspension while trail riding slow over larger bumps. When the ice melted I investigated a bit a found the transfer rod has some play in it. (See YouTube Video)
Other posts say this is normal but Im thinking I have a worn bushing or spacer. Whats the fix for this?
msgt van
Looks like your bearings, index 59 on Track Suspension 2 illustration found on most Yamaha dealer sites, are shot. Here's a link to Port Yamaha, a site sponsor: https://shop.portyamaha.com/fiche_s...=Snowmobiles&make=Yamaha&year=2007&fveh=33549
vipermike2002
- Jan 19, 2006
- 07 Attak
I saw that also when I looked at the fiche. Actually emailed Kevin asking about #59. But then I started to find posts on here and people are saying it is normal.
RAMSOMAIR
Clunking of the transfer rod linearly (Along its axis) is normal. I mean the rod inside. You need new bearings in the eyes.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Agree with ramsomair your needle bearing is probably 100% gone with that much movement,I had to change these on mine(be very careful installing new as the oem bearings are a plastic cage&pretty easy to damageClunking of the transfer rod linearly (Along its axis) is normal. I mean the rod inside. You need new bearings in the eyes.
RAMSOMAIR
I have removed my transfer rod every couple years and cleaned the needles with Brake Kleen then repack with grease. 30,000km and still good!
vipermike2002
- Jan 19, 2006
- 07 Attak
I take it I need a press to remove and install new bearings?
stevieu1
I did it without a pressI take it I need a press to remove and install new bearings?
RAMSOMAIR
Deep socket and a vice
Brotherdan
- Sep 8, 2017
- Belmont,maine
You can do it with an arbor press or vise(may need to use a shallow socket depending on size of vice)also there are 2 small shaft seals on either side of bearing that should be replaced.can press in or use a bushing/seal driver setI take it I need a press to remove and install new bearings?
vipermike2002
- Jan 19, 2006
- 07 Attak
Am I risking anything driving the sled with this issue?
msgt van
Wearing out the rod mount due to the slop so the new bearings and seals won't fit properly...just a guess on my part.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
If the rod comes apart it could start a #*$&@ storm of broken pieces potentially destroying your track.......worst case scenario.Wearing out the rod mount due to the slop so the new bearings and seals won't fit properly...just a guess on my part.
vipermike2002
- Jan 19, 2006
- 07 Attak
With track lifted off the ground transfer rod does not move much at all.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Am I risking anything driving the sled with this issue?[/QUOTE
no they don’t have a lot of travel anyway but they play a very important role of transfer in the mono skidWith track lifted off the ground transfer rod does not move much at all.
- 149K
- 39K
